Results 1 to 25 of 58
Thread: Transmission Dead, Planning Rebuild, Questions About Upgrades
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    Some of you may remember me having issues a little bit ago. I changed the fluid and filter and things were pretty good until yesterday. I drove to my parents in Ft. Lauderdale, went to get on the highway, it downshifted, and slipped shifting up again. When I got of the highway it was jerking and downshifting hard. Then after a couple lights, it wouldn't move from a stop and went into failsafe.
    So anyway, I'm planning on driving my dad's car back to Tampa and having it rebuilt maybe by a local shop here. (No don't want a 6-speed, like the Auto for traffic).
    Few questions:
    1) I'm going to get a new torque converter. I have a non-sport car.
    - Can you put a sport torque converter in?
    - I know it has a higher stall speed, is it worth it?
    - Will it work with my non-sport EGS computer or cause problems?
    - Who do you recommend for torque converters. I've seen people link Revmax. Are they quality?
    2) I want to address the valve body at the same time.
    - Can they be rebuilt?
    - Or should I just replace it?
    3) I plan on also replacing: rear main, coolant passage cover, guibo, center support bearing, CV joint at diff, transmission mounts
    - Am I missing anything?
    - Do I need to think about rear diff stuff at the same time or rear wheel bearings?
    4) are there any other things I should address at this time and/or upgrade?
    Thanks for the input.
    -Ed
    1998 740il | 9/97 build | 233k | schwarz 2 | sandbeige
    mods: m-pars | Bilsteins & B&G springs | suede headliner | Arduino w/ custom I-bus coding | Android HDMI on nav | ValentineOne | StealthOne | llumar ceramic tint | bmw aux w/ 2A usb charging
    retrofits: full nav | MKIV | bluetooth TCU | SES voice recognition | BM53 w/ AUX input | video module w/ AV input | backup cam | I-bus 6 CDC | oem sirius xm | oem xenon | power rear sunshade and side shades | PDC front and rear | rain sensing wipers | BMW DWS tire pressure monitor | interior and exterior lighted door handles | front seat heaters | heated steering wheel | euro rear fog lights | ski pass with non-ski pass arm rest | folding mirrors
    Dec 2009
    Dallas,TX
    '98 E38 740IL
    I'm in almost the same boat, my 01 had a bad transmission when i bought it. Ordered replacement trans from local seller, the bought a used sport TC, and from my understanding the sport tc will operate without a sport EGS but not perfectly..lucky for me i've got one for my car.
    As for the other stuff, I am also doing the rear main seal, water passage, guibo,CSB, transmounts. I might want to change the fluid on the rear diff,and wheel bearings but those really can be done later if it comes down to it since you don't have the get the car jacked up high to do them.
    but that's me, i'm sure more experienced members will chime in on the matter.
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, 18" Style 67s, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, E63 M6 mufflers, 2.50" X-Pipe, Shadowline - Awaiting a new transmission.
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, Coilovers, 3.15 LSD Rear diff.
    lA, ca, lA
    BLK 01 sp,17 f150 cc
    If mine ever goes I'm going to these guys https://www.levelten.com/default.asp Course the price is high who cares !
    Jan 2016
    Ca
    2001 525it
    I would call peter schimit transmissions he is an authorized zf builder, he is in Burlingame ca., I don't have the phone number. He has been around for about 30 years.
    Jul 2018
    Upstate NY
    2001 740i
    Damn dude that thing held on for ever. Find some one with a good rep and warranty.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Good feedbacks on these guys: https://www.ebay.com/itm/BMW-X5-4-4L...p~Di:rk:7:pf:0
    I have never used them, so no idea.
    $2,250 on their website: https://autotransparts.com/cart.php?...t_detail&p=995
    Dec 2015
    DMV
    00 BMW 750
    If you have the money for a higher stall torque converter, get one, it's worth it. It does not require anything but swapping the torque converter out, not connected to electronics in any way. I have a revmax higher stall converter and it's great. Revmax is good, I would recommend them.
    Feb 2017
    Charlotte, NC
    -98 E38
    I would consider replacing the parking pin. I rebuilt my gb due to a broken a-drum and didn't do this. The pin broke shortly after now the parking gear won't engage; have to use the $*&@ (hand) foot brake when parking. My thoughts are that it can be fixed without pulling the gb. Will have to address this at some point...
    jt -98 740iL
    Dec 2009
    Dallas,TX
    '98 E38 740IL
    Quote Originally Posted by tjpike View Post
    Higher than stock sport? I have a sport tc coming and don't want to regret it
    Sent from my SM-N950U using Tapatalk
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2
    - Can you put a sport torque converter in? YES
    - I know it has a higher stall speed, is it worth it? Up to the driver
    - Will it work with my non-sport EGS computer or cause problems? Should not, just shifts a few beats later.
    - Who do you recommend for torque converters. I've seen people link Revmax. Are they quality? YES
    - Can they be rebuilt? YES - Revmax $599 with new solenoids - well worth it
    - Or should I just replace it? REVMAX
    - Am I missing anything? Be sure to use a FILTRAN filter and proper fluid.
    - Do I need to think about rear diff stuff at the same time or rear wheel bearings? That's up to you.
    4) are there any other things I should address at this time and/or upgrade? If you have the transmission rebuilt, replace the TC and rebuild the valve body, you'll be in great shape. Raw cost on that is $500 trans kit, $600 valve body rebuild, $300 range on reman torque converters - Goes up from there.
    "NRVOUS7"
    2001 - DINAN 7 Sport - S62 Swapped 6 Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2002 - DINAN X5 - 4.6is Supercharged
    Titanium Silver / Black
    @scotthduke on Instagram
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    Wow shop near me in Tampa quoted $4800 for a "soft parts" rebuild. That obviously includes labor. I don't have the time nor space to do this myself, so I need to find someone to do it. The shop near my parents in Ft. Lauderdale doesn't rebuild them -- they send them to Eriksson in CT. I have no problem with that because they are great, but there's the cost of shipping involved, which may still be worth it. Doesn't help that the car is 250 miles away from me right now.
    Dec 2015
    DMV
    00 BMW 750
    Quote Originally Posted by Sabreslight View Post
    In my case i have a 750. They never had the higher stall from factory.
    Dec 2009
    Dallas,TX
    '98 E38 740IL
    Lol yea they also never got the good rear end.
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    Well this sucks. Looks like this may take longer than I thought. Waiting to hear back regarding pricing for removal and sending to Eriksson. Kinda makes me wish I just prophylactically had the transmission removed and rebuilt while I was living in CT. Sigh.
    Dec 2015
    DMV
    00 BMW 750
    Thats why I got both now
    Quote Originally Posted by racer2086 View Post
    Perhaps also look into level 10, I've heard good things. They might be a tad more expensive though
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    Yeah, I looked at their website. Looks good! But it would still require some shipment to NJ.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    I'm lucky to have that many transmission shops around me in a two hours drive radius!
    Indiana
    2001 740i M sport Imola
    What was your mileage when your tranny went?
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    237,xxx
    Waiting to hear on turn around time to get the tranny to Eriksson and back and installed. Price actually seemed quite reasonable from this shop to go that route.
    Feb 2012
    Bottom of a Bottle
    96 740il, XJS & CBR1000F
    Eriksson is top notch, you can't go wrong with them and they will answer all your questions.
    The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
    When answering my questions please use a qualifier if you are not sure.
    The more I work on this car the less I respect German engineering.
    When you speak in Absolutes you are always wrong!
    Semper Fi
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Is Eriksson more expensive than the others? I guess i will need this in a year so.
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    Ok so the transmission is out and on the palate on the way to Eriksson. We will see how things go.
    He is going to call me with pricing and a list of other stuff to replace. He was talking about going Lemforder for the guibo. Thoughts? Should I just go genuine on everything? I'm afraid this is going to be another $1000 added to my bill doing the driveshaft stuff.
    Another unrelated question. Any info on converting prefacelift to steptronic? From searching, the posts are almost 10 years old. Some say you have to get a Euro trans computer. Others say it made their car run weird because of the different stall speeds of the torque converters? Anyone have info?
    Dec 2009
    Dallas,TX
    '98 E38 740IL
    On the topic of step on a pfl car, I did it and yes you need a euro egs for it to work or at least the coding of one, if I could figure out how to I could get you mine. Seeing as the euro pfl step equipped cars is the same as ours with the same tc you'll be fine. That oly applies to FL cars with a sport egs.
    Jan 2006
    Tampa, FL
    98 740il, 00 540i
    Ok, so I need a Euro EGS from a PFL car that is a non-sport. How the heck do I get the right one of those? I guess maybe by realOEM part number?
    Dec 2009
    Dallas,TX
    '98 E38 740IL
    Coorect a euro egs from a step equipped car from the same year. Realoem was hit or miss for me. What I did was run the Vin from the egs I was looking at to see if it was step optioned. It might help that mine is from a 735i.
  1. M10 rebuild advice please (Upgrading 1.8L to 2.0L questions)
    By amarino in forum 1975 - 1983 (E21)
    Last Post: 09-12-2012, 08:55 AM
  2. Transmission blowing up. Rebuild, replace or upgrade?
    By Wertles in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-17-2012, 11:34 AM
  3. 4hp22 trans upgrade/rebuild question.
    By constantproject in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-01-2012, 01:24 PM
  4. E34 M5 Transmission Rebuild Questions
    By niks325i in forum 1988 - 1996 (E34)
    Last Post: 07-31-2007, 11:03 PM
  5. System Plan And Questions
    By COLLOSUS in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-15-2003, 10:44 AM
