RM European Auto Parts
Results 1 to 3 of 3
Thread: 2001 E46 - Changed battery and now instrument cluster playing up
    Jan 2019
    Kent
    2001 BMW 318 SE
    As title, I had the battery changed on Friday and the cluster is not right since. See the following video...
    https://www.youtube.com/watch?v=yaWaFW26LWo
    Any ideas? The mechanic used a gizmo to keep electrical continuity while he changed the battery. Car drives absolutely lovely since having the new battery in, it's just this weird thing keeps happening when I start!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Sorry to tell you, but the "electronic gizmo" which supplies power backwards through the OBD port is a BMW's worst enemy. It's known to kill computers, and it looks like it might have toasted your instrument cluster.
    I can't tell you why this happens, but I've heard of it happening many times. I find it hard to believe anyone would use such a thing, because they're too lazy to reset the clock.
    I do not think it's going to fix the problem, but you could TRY undoing the battery negative cable for a few minutes.
    Chris Powell
    BMWCCA 274412
    Jan 2019
    Kent
    2001 BMW 318 SE
    Thanks for the info. I didn't see exactly what the mechanic used or where, I just dropped the car off and came back round an hour later. I asked if he was able to keep electric continuous or did the radio need unlocking, and he said he had used a tool to keep power in the circuitry. That's all I know. I'm seeing him tomorrow and will feed back what you say above. Cheers!
  1. Battery died and instrument cluster/OBC wont work
    By LABMW740i in forum 1995 - 2001 (E38)
    Last Post: 01-19-2019, 02:44 AM
  2. High battery drain from instrument cluster
    By Avec in forum 1991 - 1999 (E36)
    Last Post: 09-14-2014, 12:12 AM
  3. Battery light on instrument cluster stays lit...
    By rattlehedchris in forum 1983 - 1991 (E30)
    Last Post: 05-12-2007, 02:38 AM
  4. Need battery's for Instrument Cluster ,where to buy them
    By Slow325i in forum 1983 - 1991 (E30)
    Last Post: 11-08-2005, 02:34 AM
  5. Disconnect battery before removing instrument cluster?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 01-19-2004, 02:42 PM
