Results 1 to 3 of 3
Thread: Mass air flow sensor
    Jan 2019
    Sinking Spring PA
    2010 328xi
    I have a 2010 328xi N52 engine that has a rough idle and sometimes stalls at idle. It runs good at all other RPMs. The rough idle goes away when the mass air flow sensor is unplugged but I didn't try to run it on the street
    with it unplugged. If the problem was from a vacuum leak instead of the sensor would it run better when unplugged ? It is also throwing a fault code for the MAF which I understand could be from either the MAF or a vac leak.
    Also I saw on a post that there was no difference between a 328xi and a 328i xdrive but I see suppliers listing sensors for both with different year restrictions. Thanks for any help !
    Jul 2004
    Houston, TX
    36 Cylinders
    Post the codes if you still have them.. but yes, often it's vacuum leaks or maf, unless there is a maf signal error. Then I would lean more for maf.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2019
    Sinking Spring PA
    2010 328xi
    Some codes are 2D06 MAF and 2AB4 control unit int fault along with a bunch of misfire codes witch are probably from the fuel metering do to other problems. I cleared codes and started the engine and took it up through the RPMs but did not drive it.
    I checked codes again and 2D06 was back. Is there a spec for the MAF output at a given RPM , throttle position , and inlet air temp ? With the scanner connected and set to PIDs, I found the sensor output was changing with throttle position but I have
    no way of knowing if it drifted or span is correct.
  1. Mass Air Flow Sensor??
    By savemike in forum 1991 - 1999 (E36)
    Last Post: 06-12-2004, 05:23 PM
  2. Need Tip On Cleaning Mass Air Flow Sensor
    By Logiks in forum 1983 - 1991 (E30)
    Last Post: 01-19-2004, 04:20 AM
  3. Wtb-mass Air Flow Sensor
    By 328ISJOEY in forum BMW Parts Wanted
    Last Post: 07-07-2003, 11:48 PM
  4. WTB: your low miles 96-99 Stock M3 Mass Air Flow Sensor
    By Dinanify in forum BMW Parts Wanted
    Last Post: 04-19-2003, 05:54 AM
  5. FS BMW OE Mass Air Flow Sensor for 1996-98 OBD II M3
    By BAADDOG in forum BMW Parts For Sale
    Last Post: 04-19-2003, 05:49 AM
