Results 1 to 15 of 15
Thread: Gas Smell and Wet Fuel Filter
    Jul 2017
    Usa
    2000 BMW 540i M
    I thought I noticed a gassy smell the past couple of days coming from my car. Tonight when I looked under my car the fuel filter was wet to the touch at the front. (my plastic cover shroud is broken so the filter is in open air under the car) I believe my filter is leaking and it can't hurt to swap it anyways cause I'm passing 140k.
    When I looked online I found the fuel filter for cheap ($20 ish) but there are also far more expensive options with the pressure regulator ($75+). My question is can I just buy the normal filter or do I need to buy the one with a pressure regulator? Is it built in to the filter by default?
    Sent from my LG-H872 using Tapatalk
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    Quote Originally Posted by trevzor4242 View Post
    Depends on what year your car is. I think post-facelift have the pressure regulator in the filter and pre facelift had it in the fuel pump itself. Regardless I'd get one with the built in pressure regulator, as if your pressure regulator on the fuel pump goes bad, then you still have the one in the new fuel filter accomplishing the same task.
    The more expensive filter with the regulator is definitely what I would purchase & it should only cost about $50. I got mine off of RockAuto I think, it's a MANN
    https://www.rockauto.com/en/moreinfo...411625&jsn=421
    Part is MANN WK532
    2003 530i M Sport [Black Sapphire Metallic & Sand Interior]
    IMG_1075 by Alex Wilson Photography, on Flickr
    Jul 2017
    Usa
    2000 BMW 540i M
    Sorry, I should've said my car. It's a 2000 540i. If the pressure regulator is in the filter on those then wouldn't I have no choice but to get it anyways?
    San Jose, CA
    1997 BMW 540i 6 speed
    No choice. Replace the hoses, too.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Yep, replace the oem fuel filter with regulator (Mann ?), the hoses with new clamps, and patch or replace that shroud under the car. The fuel filter/hoses lines should not be exposed.
    Jul 2017
    Usa
    2000 BMW 540i M
    Well, last night I put paper towels underneath the filter and checked this morning for signs of any leakage. Sure enough there's a slow but substantial leak... Everything I own is breaking looks like a new filter/pressure regulator, clamps, and hoses are on order. Thanks for the input
    Jul 2017
    Usa
    2000 BMW 540i M
    Oh- and I'll get that plastic shroud locally too when I find a parts car
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Everything I own is breaking Sent from my LG-H872 using Tapatalk
    I know how you feel...
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Make sure you connect the hoses to the filter exactly the same as they are now connected to your old filter. It does make a difference and won't run correctly if you hook the hoses on the back of the filter up wrong. Maybe mark them before you remove them.
    Jan 2015
    Shreveport Louisiana
    your Y/M has the separate regulator and filter, the cheaper of the two. if any doubt on which one to get, look up your car on realoem.com, get the part # and look from there. iirc tubing hookups are different on the two. and yes replace the hoses while in there, look especially at the one that comes off the filter and does a quick 90 degree turn.
    JimLev's Avatar
    Sundance Mesa, NM
    He says he has a 2000 540 so his filter is the one that has the regulator in it, the more expensive of the two.
    The one that 1823alex linked to is it.
    Jan 2015
    thanks for catching my oversight Jim, saw it was a year 2k, but didnt see the 540.
    Jul 2017
    Usa
    2000 BMW 540i M
    Is the only way to get clamps and hoses by buying the oem ones?
    Jul 2010
    Ontario, Canada
    2003 BMW 530i
    No need for a trip to the dealer.
    I replaced my fuel filter 6 years ago using Gates 4219D hose and "fuel injection" hose clamps (type with screw and nut to clamp, rather than the more common gear clamp) and have had no issues in that time. Cost at NAPA was ~$10 CAD, so should be less than US$10 for you. I'm just coming due for the next Inspection II & I'll be doing the same again.
    Regards
    RDL
    JimLev's Avatar
    Sundance Mesa, NM
    I just did mine last month. I used screw clamps as they were what I put on when I last change the filter 100K miles ago.
    I do have the OE clamps and the tool, but it's sort of a pain to cut them off, the screw clamps are easier to deal with.
    Here's a pic of the tu filter connections. The 2 hoses that connect to the back of the filter (right side in pic) are the ones you don't wan't to mix up.
  1. water in gas BEYOND fuel filter (i think)
    By jp122957 in forum 1983 - 1991 (E30)
    Last Post: 10-27-2010, 08:19 PM
  2. 2 things: Oil Filter question/ Gas smell concern
    By 5ickRide in forum 1983 - 1991 (E30)
    Last Post: 09-05-2009, 08:58 PM
  3. Gas smell after fuel filter change....
    By 330Maniac in forum 1999 - 2006 (E46)
    Last Post: 06-20-2007, 04:49 PM
  4. I think i have a gas leak at the fuel filter
    By 1991318IS in forum 1983 - 1991 (E30)
    Last Post: 04-19-2007, 10:39 PM
  5. WTB: e36 gas tank and fuel filter cover/sheild
    By ///MPower3 in forum BMW Parts Wanted
    Last Post: 06-02-2005, 11:43 AM
