Results 1 to 9 of 9
Thread: Bottom mount air filter tubes
    Sep 2008
    selah WA
    1996 m3
    Post pictures of bottom mount air intake tubes.
    It’s my last pipe to make on my car and I’m stuck. I have the tube mocks up outside the car but I can only picture getting it in with the motor mount removed. Is everyone using three couplers or two? 3” or 2.5”
    Note it is easy without a/c. But my curiosity is how it’s been done with a/c.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Are you trying to go up between the motor and frame rail to behind the headlight or low to the fog light area in the passenger front corner of the bumper cover?
    Sep 2008
    selah WA
    1996 m3
    My intercooler is above the sub frame. While poking around my only option seemed to be up between frame rail a/c and spa manifold to behind the headlight.
    I would be ok behind the fog light but can’t see a path to get there
    Virginia
    97' m52 turbo
    It is possible to keep the AC compressor, a couple ways.
    Before I realized that the you would need an extended motor mount bushing (to lift / rotate the motor to the drivers side of the engine bay) for the intake pipe to clear the manifold - I modified a conical air filter and mounted it directly to the turbo inlet, its tip sat right behind the compressor
    I think I actually used this filter: I didn't like having the filter absorb the heat underneath the manifold or the size of it.
    So I moved to the bumper
    I ended up getting irritated when I was trying to install an additional AUX fan and did away with AC
    But yes, keeping it is possible. Its just a matter getting the intake pipe between the front of the turbo manifold and frame/ other parts. Extened motor mount / shimming. I would guesstimate you need an additional 2-3 inches of space there (if on stock motors mounts) for a 3" pipe.
    Jun 2005
    New England
    I used oval pipe, cut and welded in a curving shape and raised the AC and cut away part of the tensioner bracket to put a large cone filter in the fog light area under the bumper and just in front of the wheel well liner. Going up past the frame rail to the headlight area is easier.
    Sep 2008
    selah WA
    1996 m3
    Quote Originally Posted by 328iFun View Post
    I had wondered about a different motor mount. I really think if I had a 1/4” extra I could make it work.
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Used an old fog light housing, removed the glass and cut off the back, epoxied a short piece of 1.5" aluminum tube to the back and used aviation ducting to bring it up to the top mount turbo area.
    Makes a huge difference. Compressor cover is actually not HOT after running the car on the road.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    I would try to get some elbows made where you design the pipe to have a weld in the center of the oval section. This will allow you to squish the open ends of the elbows to an oval section to clear the frame rail. Weld those together after forming and you should have a pipe that fits. Use the thinnest wall pipe you can find.
    Virginia
    97' m52 turbo
    Quote Originally Posted by lisnowboarder View Post
    More than likely 3" - a 2.5", certaintly. Could always dent the 3" tube at the manifold if needed as well.
    If I'm not mistaken before the bell housing hits the upper part of the firewall, we have a good 3-3.5 inches or so
    If I we're able to do it all over again, I would find the longest motor mount available and I'd shim it if needed.
  1. E30 WTB M20 bottom mount, air/h20 cooler ,h20/air rads
    By harvardf in forum Forced & Chemical Induction Parts
    Last Post: 05-18-2012, 11:25 AM
  2. two tubes hooking up to air filter?
    By nodnerb04 in forum 1991 - 1999 (E36)
    Last Post: 11-13-2011, 08:27 PM
  3. WTB: Cold air intake tube and filter for a 318is (1994_
    By RebelScum in forum BMW Parts Wanted
    Last Post: 10-26-2009, 11:17 PM
  4. WTB Air filter intake tube
    By 2002jm in forum 1975 - 1983 (E21)
    Last Post: 05-31-2009, 10:21 PM
  5. FS: K&N air filter - 9" Cone/3" Tube
    By bmwm3n528 in forum BMW Parts For Sale
    Last Post: 02-14-2005, 12:35 AM
