Results 1 to 4 of 4
Thread: Spark Plugs Lean or Normal?
    Jan 2019
    LA
    E36
    Look like they are lean? Thanks
    Sent from my Mi MIX 2S using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E36 forum
    Jan 2016
    Ca
    2001 525it
    In the old days of racing you would read plugs a given rpm then shut the engine off,,I would have a shop read live data if your concerned, but seeing how the engine management system does every thing it's probably alright
    McKean township Pennsylva
    1999 M3 , 1999 328is
    Looks pretty good to me. I'd have doubts that you would ever be overly lean as the ECU should take care of it all. Granted that assumes you have good O2 sensors and no vacuum leaks.
    I've seen a similar color to plugs from lead fowling when I put too much lead additive in my Austin Healey. But a nice light brown color like that isn't bad. If it were actually lean I would expect a lot more buildup.
  1. Do these Spark Plugs look normal?
    By BMWObsession in forum 1988 - 1996 (E34)
    Last Post: 02-29-2012, 02:02 AM
  2. Is it normal for spark plugs to look like this?
    By jbarger4 in forum 1991 - 1999 (E36)
    Last Post: 05-01-2010, 04:09 AM
  3. Replies: 12
    Last Post: 01-02-2010, 12:46 PM
  4. Does this spark plug wear look normal ?
    By pcy in forum 1991 - 1999 (E36)
    Last Post: 03-21-2005, 07:51 AM
  5. spark plugs white as snow.. running lean?
    By SupaBimma in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2005, 12:26 AM
