Results 1 to 3 of 3
Thread: Need feedback on brake condition please
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Hi all. While we are forced inside by our -35C winter here in Quebec I thought I'd take a look at my front brakes. I am new to vehicle maintenance and I would appreciate some feedback on the following please:
    1. The pads are branded as Ferodo and they seem to have plenty of material left. It should be ok to keep them right?
    2. The inside of the piston shows some corrosion. Maybe this is why the pads weren't fully released when I spun the disc, before disassembly? They were rubbing. Should I rebuild the caliper?
    3. The disc shows some chipping on the edges, is that noteworthy?
    4. If the brake hose shows no external sign of wear, should it be changed regardless due to age?
    Thank you!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    pads look o.k.
    there are seal kits available for the pistons, see here http://bmwe32.masscom.net/sean750/ca...akeCaliper.htm . I once bought these seal kits from autohausaz.com
    or if too much corrosion, rebuilt kits are available from various sources
    disk chipping should be no problem, that is outside the area where the pads usually go
    while you are working there, I would also change the brake hoses, they are not that expensive, often they even come free of charge on brake kits.
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Thanks Shogun as always.
  1. Brake Problem or Suspension Problem?? Need feedback.
    By fsclax330 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-26-2012, 12:01 PM
  2. Need feedback on aftermarket OSV versus ebay kit please
    By bsenoran in forum 1995 - 2001 (E38)
    Last Post: 04-12-2011, 04:22 AM
  3. i need info on how to change brake pads??please help
    By vlady1011 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-05-2008, 10:59 PM
  4. Need some feedback guys and gals.......please
    By mesmerize in forum 1995 - 2001 (E38)
    Last Post: 01-23-2006, 06:47 AM
