Results 1 to 2 of 2
Thread: Air Bag Light
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Air Bag Light
    I realize this subject has been covered. I thought it was my scanner that was not properly working so I took my car to an independent technician that I trust. Apparently I still have the same problem...passenger air bag issue. (see enclosures) I checked the plug connections...appears okay. No broken wires. So I need some advice/help on what can be done to resolve this issue. Thanks in advance for your help. You may need to click on each enclosure to open the page.
    Attached Files Attached Files
    May 2015
    Maryland
    1998 M Roadster
    That last image is upside down. Did you take the airbag connectors apart and look at the pins and sockets?
    On a side note, it is an airbag...battery disconnected and let it sit before working on it to insure the airbag firing circuit caps bleed down.
  1. Air Bag light stays on 1 minute
    By speeed9596 in forum 1991 - 1999 (E36)
    Last Post: 03-06-2002, 04:21 AM
  2. Air Bag Light - for no reason?
    By T///MW in forum 1992 - 1999 M3 (E36)
    Last Post: 01-07-2002, 08:23 AM
  3. Air bag light came on.
    By hyperknight in forum 1992 - 1999 M3 (E36)
    Last Post: 09-16-2001, 03:18 AM
  4. Need Help ASAP, Air Bag light is staying on.....
    By Spencer in forum 1992 - 1999 M3 (E36)
    Last Post: 09-06-2001, 05:57 PM
  5. Air Bag Light
    By Breyton E36 in forum 1991 - 1999 (E36)
    Last Post: 07-28-2001, 04:10 PM
