Results 1 to 7 of 7
Thread: Bilstein rear shock bushing falling out ?????
    Sep 2016
    Charlotte, NC
    1995 BMW M3 Coupe
    I noticed the bushing in the Bilstein shock was falling out. The rubber grommet on the screw side was actually covering half of the bolt head. I had to beat it back this far just to be able to get a socket on bolt head.
    1- Has anyone experienced this?
    2 - I'm assuming the bushing is supposed to be centered in the housing (doing so it would protrude about 1/8"either side).
    3 - There was no washer on the bolt head (There will be now), nor does REALOEM indicate there should be one there.
    Any thoughts?
    PS - Can't get the pictures to rotate
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    You didn’t install the washer. Their kits include it (just about every shock manufacturer does).
    Get a washer on it and continue to drive.
    Oct 2003
    Seattle
    99 M3
    Yes missing the captive washer.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Make sure you also tighten that bolt with the rear back on the ground with the shock under load.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by BMWManiac View Post
    Or measure center of wheel to fender lip with car on ground, then jack the rear Spindle to that height after initial bolt installation (while car is on jack stands) and apply the final torque with Spindle jacked to ride height.
    Never done it that way however, and have done several sets.
    Jan 2006
    Oakhurst, CA
    Considering the bushings slide out... it is not necessary to preload the suspension for the shock lower rubber. They likely rotate into ride height position.
    Sep 2016
    Charlotte, NC
    1995 BMW M3 Coupe
    Thanks everyone. I put it all back together with a big *ss washer this time. i did tighten it up on the ground. Didn't do it that way last time.
  1. Bilstein Rear Shock Bushings?
    By 99M34life in forum 1992 - 1999 M3 (E36)
    Last Post: 10-04-2013, 10:40 AM
  2. Bilstein Rear Shock Bushing Help
    By TCarlisle in forum 1991 - 1999 (E36)
    Last Post: 02-06-2013, 08:38 PM
  3. WTB new bilstein rear shocks
    By TheNorthWaves in forum BMW Parts Wanted
    Last Post: 10-02-2006, 12:27 AM
  4. Possible (Bilstein) rear shock problem
    By Hammdy in forum 1992 - 1999 M3 (E36)
    Last Post: 08-12-2006, 06:46 PM
  5. Bilstein rear shocks - what goes on top?
    By Reed in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2006, 11:10 PM
