Results 1 to 3 of 3
Thread: Few questions. I changed my spark plugs and ignition coil pack! My car is even worse!
    Jan 2019
    San Francisco
    Chevy Malibu 2004
    Help!. I changed my spark plugs and ignition coil pack! My car is even worse!
    Now it smells really strong of gasoline. Its running rough. Idling up and down. When i come to a stop or slow down it either shuts off or almost shuts off. But has no problem starting back up. Im sure there is an oil leak because i can see the debris building up. But that was there before i changed the spark plugs. Now my check engine light is on and the code it reads is p0300 multiple cylinder misfire. Not sure what i should do from here
    Last edited by Jdarytway25; 01-19-2019 at 05:09 PM. Reason: Mispelled and mistyped
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    No disrespect intended, but if that happened to me I'd double check everything. Plugs in all the way. Coil packs on tight. Wires connected right -- not accidentally swapped. Nothing else accidentally disconnected, like a vacuum hose.
    Mar 2017
    Casper, Wyoming
    2006 BMW 750li
    Have you resolved this issue?
  1. 06 330i spark plugs and ignition coil question!
    By Resetg in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-09-2015, 08:46 AM
  2. E39-How To Replace Spark Plugs and Ignition Coils-Video
    By blackGM in forum 1996 - 2003 (E39)
    Last Post: 05-10-2015, 11:18 PM
  3. E36 WTB: E36 105/140 Amp Alternator, 6 spark plugs and 6 coil packs
    By Knicks in forum BMW Parts Wanted
    Last Post: 07-06-2011, 12:31 PM
  4. DIY for Spark Plug and Ignition Coil change?
    By tsouzee in forum 1996 - 2003 (E39)
    Last Post: 05-05-2009, 10:26 AM
  5. Spark Plugs and Ignition Coils
    By bimmerfiver in forum 1996 - 2003 (E39)
    Last Post: 02-17-2007, 01:09 PM
