Results 1 to 4 of 4
Thread: Replacement Check Panel?
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    I was pleased to find that the Euro Clock is available new, and at a price not that much higher than used on Ebay + shipping. I went this way and happy with it.
    Is the same true of the check panel? I need its guts mostly, I have burned out LEDs and could not repair them by reflowing solder. I have both missing useful lights (oil) and hyperactive less useful lights (rear lights).
    Also interested in known good replacements. This is for an 89 with no SRS.
    edit - what a fool for not searching the part # thru real OEM first. They're available but pricey around $245
    62141375750
    Jul 2013
    CT
    Interesting option I stumbled upon. Water temp seems deeply redunant... oil temp/pressure/AFR would be my choice but then again I didn't invent it
    https://www.ebay.com/itm/Tangent-Inn...EfFB:rk:2:pf:0
    Sep 2014
    KS
    e24e30e36e39e90
    Best bet for a check panel is to look for part-outs on Craig’s list, or row52.com for salvage cars if they cover one near you. You can pick one up real cheap either way. I picked one recently from a yard that wasn’t SRS to ‘fix’ the flashing air bag light that is damn near impossible to turn off without crocodile tears and three strands of hair from a unicorn’s mane.
    Jul 2013
    CT
    Anyone know about compatibility between different model numbers on the Non SRS unit?
    Found attached on ebay with is a few numbers off mine (mine is pic with my hand)
  1. Replacement Nose Panel
    By ///M3ryder NY in forum 1992 - 1999 M3 (E36)
    Last Post: 11-27-2003, 02:43 PM
  2. Euro check panel in an SRS car?
    By Digitalwave in forum 1983 - 1991 (E30)
    Last Post: 10-16-2003, 07:35 PM
  3. Replacing door panels
    By bmw325iman in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-02-2003, 09:22 PM
  4. Replacing Body Panels?
    By Rollen318i in forum 1983 - 1991 (E30)
    Last Post: 11-15-2002, 05:40 PM
  5. Pics of the ECIS E36 M3 Replacement Splash Panel
    By jaramill in forum 1992 - 1999 M3 (E36)
    Last Post: 07-05-2001, 08:16 PM
