I was pleased to find that the Euro Clock is available new, and at a price not that much higher than used on Ebay + shipping. I went this way and happy with it.
Is the same true of the check panel? I need its guts mostly, I have burned out LEDs and could not repair them by reflowing solder. I have both missing useful lights (oil) and hyperactive less useful lights (rear lights).
Also interested in known good replacements. This is for an 89 with no SRS.
edit - what a fool for not searching the part # thru real OEM first. They're available but pricey around $245
62141375750
Interesting option I stumbled upon. Water temp seems deeply redunant... oil temp/pressure/AFR would be my choice but then again I didn't invent it
https://www.ebay.com/itm/Tangent-Inn...EfFB:rk:2:pf:0
Best bet for a check panel is to look for part-outs on Craig’s list, or row52.com for salvage cars if they cover one near you. You can pick one up real cheap either way. I picked one recently from a yard that wasn’t SRS to ‘fix’ the flashing air bag light that is damn near impossible to turn off without crocodile tears and three strands of hair from a unicorn’s mane.
Anyone know about compatibility between different model numbers on the Non SRS unit?
Found attached on ebay with is a few numbers off mine (mine is pic with my hand)
