Results 1 to 9 of 9
Thread: 5 Lug Conversion
    Dec 2018
    Indonesia
    E30 318i
    5 Lug Conversion
    Hello guys,
    I'm going to ask a question that has been discussed quite a few times. But I believe my situation is a little different. So please hear me out first before shooting flames on me.
    I have an E30 318i MY 1990 with M40 engine and I'm planning to convert it to 5 lugs and rear disc brake. I know that many of you would suggest me to use M3 rear suspension parts or from ti models. The problem with that is those models were not sold in my country (Indonesia). So as you would imagine, these parts are almost non existence.
    Is there any other solution I can look into? Here we have e30 sedans e36 sedans, e46 sedans.. These are pretty much all the models BMW officially sold in here.
    Here's what I have in mind:
    I can source e30 325i trailing arms and change the hub and disc brake assembly using e36 parts. As for the front setup, change the hub and disc assembly using e36 parts.
    Is my solution possible?
    Sent from my SM-P355 using Tapatalk
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    I am not conversant in the rear brake set up between the different models - is there no rear disc set up that bolts onto your current hubs? I struggle to see what benefits a five bolt setup offers a relatively stock E30.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    Just gives wheel options, i imagine
    No e30s again.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    There used to be a site called extradrei.com that detailed all of this. It appears to be gone. But if I recall correctly, there were some other options. Up front you could use the E36 M3 struts. In back you could use the either E36 ti or Z3 arms. There are many considerations to take into account that can make or break your swap. But that should get you started in your research for the specific parts you'd want. However none of them are simple bolt on changes.
    With that said, I'd be curious to know why you want a 5 lug swap. There may be other paths to your goal that are simpler and cleaner.
    "Howdy, Folks!"
    Dec 2018
    Indonesia
    E30 318i
    Quote Originally Posted by somecarguy View Post
    Quote Originally Posted by superj View Post
    Quote Originally Posted by richardodn View Post
    Ok. Why 5 lug setup? Yes you are right..more wheel option. But to me the most important bit is the rear disc brake
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    This site usually has some good info. Didn't read through it, but here you go: https://www.e30zone.net/e30wiki/inde...Lug_Conversion
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Dec 2005
    No e30s, again :(
    If you only wish to have rear disc brakes, any 6 cylinder e30 has rear discs. Just find some 325i or 325e stuff to swap over
    No e30s again.
    323i E30's Avatar
    Jan 2013
    Europe
    (...) any 6 cylinder e30 has rear discs. (...)
    Except for the 320i.
    Not sure if all of those have rear drums, but the one I owned did.
    ^ true story
    Jul 2013
    CT
    I don't know anything about wheel selection but I do know that the factory brakes are quite good on the cars with four wheel discs (4 lug) and can't see needing much more, even with a Sxx conversion.... for a road car. Great balance of pedal feel / parts cost / lack of noise. If you have track/dual purpose ambitions obviously there are other considerations.
  1. E30 M3 suspension/5 lug conversion parts
    By ct_m3 in forum BMW Parts For Sale
    Last Post: 05-24-2004, 05:42 PM
  2. E30 5 lug conversion
    By M50E30 in forum 1983 - 1991 (E30)
    Last Post: 05-15-2004, 07:03 PM
  3. 5 lug conversion
    By bmwQ in forum 1983 - 1991 (E30)
    Last Post: 02-10-2004, 09:10 PM
  4. 4 to 5 lug conversion (just curious).
    By ilia in forum 1983 - 1991 (E30)
    Last Post: 01-20-2004, 01:09 PM
  5. 4 to 5 lug conversion
    By KBMW222 in forum 1983 - 1991 (E30)
    Last Post: 11-01-2003, 07:02 PM
