Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: E32 750iL Calypso Red
  1. #26
    Feb 2016
    Northern ireland
    740i Sport
    Thanks guys
    Timm, it has 302 * Remote Control Anti-Theft
    The car was starting fine up until this point
    When I try to start it the alarm goes off with the hazards. And the engine turns over but won’t fire
    I didn’t find the alarm box. It seems to be buried deep in the engine somewhere. I think it’s below the wiper mechanism but I was hoping I wouldn’t need to rip that out which is why I didn’t find it. I don’t have the key to turn it off either
    There is a box behind the modules in the pic I sent of the rear seat. It has a few fuses in it which made me think it wasn’t what I was looking for
    A guy on fb had the same issue but he connected the battery with the key in the ignition turned to the on position and the car started fine
    I’m going to try that
    But for piece of mine I’d like to get this sorted. If the alarm ever went off the only way I can switch it off is disconnecting the battery which is awful
    When I picked the car up it sat for 2 weeks and I replaced the battery. Upon start up the hazards went on but I just turned them off and started the car. Thought nothing more off it. That was the beginning of my alarm trouble..
    Also, I can’t unlock the car with my keys. I have to access the car from the passenger door lock
  2. #27
    warwick RI
    E30/E32/F25
    Could this perhaps be something going on with the obc code feature Timm?
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
  3. #28
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The OBC should flash up 'CODE' if it was - but certainly worth checking. My feelings are that you don't have the Alarm System 3 as you can find no sign of it. I would think that you have something else that I a have no information on - possibly the Alpine system which was available in '93. A quick look at the circuit diagram for '93 (the latest I have) shows that it is disabled via the drivers door lock switch - so it is well worth working out what has gone wrong in there as it will have some bearing on your problem!
    My BMW Repair YouTube Channel
  4. #29
    Feb 2016
    Northern ireland
    740i Sport
    Thanks guys
    Tried connecting the battery with me in the car with all the doors shut
    Alarm rings, hazards, engine turns over but won’t fire
    Anyway, tried to get into the boot and guess what... I can’t get in.. I’ve had it open before though
    Need to look into breaking into the boot
    Timm, I’m going to look into this alpine system you speak off. Are you implying that the alarm can be turned off by turned the key in the drivers door?
    I’ll try that
  5. #30
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    try this, Trunk latch won't open? http://www.nmia.com/~dgnrg/page_38.htm
    In worst case you can remove the rear center console, there is a perforated metal piece for the ski bag opening to the trunk, use a hammer and smash it out, then you could try with a long stick to remove the carpet/cover between the taillights.
    see skibag eba for E34, similar https://bmweba.com/tag/ski-bag/
  6. #31
    Feb 2016
    Northern ireland
    740i Sport
    Thanks Shogun
    I’m going to reconnect the battery and try it. Or will that make a difference. It has soft close
    The most annoying thing about the alarm situation is the siren. The car is currently stored in an outhouse which is in close proximity to a farm house which my parents rent. So I hate making noise. As soon as the siren goes off I don’t feel comfortable trying different things to try and get it off as I don’t want to cause any annoyance to the tenants
    So is there anyway I can disable the siren temporarily? I don’t want to wreck it (yet anyway) wrecking it won’t solve the immobiliser problem as the car still won’t start. If I could just get the sound diminished it would help a lot!
    I take it the first step is to locate it
    Once I do that I believe it has source of power from a battery so cutting the wire won’t work?
    Jan 2005
    Japan
    The softclose modul is unfortunately also in the trunk, pics here http://bmwe32.masscom.net/johan/soft...softclose.html
    On my car the alarm siren is located right side (in your case driver side) in the area where the wiper mechanism is. I once remove such a siren from as parts car, but I had to access it from engine bay. Here is a pic from an E31, see the red arrow
    https://www.bimmerforums.com/forum/s...siren-location
    same on E32.
    Wait.....here is the EBA for alarm siren for E32, so there you see the wiring and the siren location https://bmweba.com/eba-01-29-9-786-206/
    Also check under rear seat left side if there are fuses for the softclose, maybe a blown fuse? But I do not have softclose, no idea where such a fuse would be.
  8. #33
    Feb 2016
    Northern ireland
    740i Sport
    Thanks Shogun
    I’ll mute the siren first and then fix the boot issue
    I have to replace the expansion bottle so I’ll remove that first to try and give myself more room when looking for the siren
  9. #34
    Jan 2005
    Japan
    Another way to open the trunk is to drill a small hole behind the license plate and then use a hook to get hold of the lever. That is in the official instructions for the German road assistance service handbook
    https://html1-f.scribdassets.com/t09...55cbc19485.jpg
    https://html2-f.scribdassets.com/t09...71f86c5b4c.jpg
  10. #35
    Feb 2016
    Northern ireland
    740i Sport
    Got the car to start Yes!
    After getting into the boot and searching it I was out of ideas Was talking to a friend and he done a quick google to find that there was a ‘secrete’ blue fuse under the back seat
    I remember reading about it but I was so focused on looking for that specific module I had I didn’t try any other ideas
    Since I was desperate I thought I’d pull the module that the fuse goes into. It is very wel burried, but I’m used to digging. After pulling the carpet to access the screw I got it out I’m still not sure what it is, but I pulled the fuse and the car turned on with no alarm issues
    It also unlocks and locks
    I’m pleased the car is running but it’s not the end of it. I’d like to fix the issue as pulling the fuse is just a ‘quick’ fix.
    What do I do next? Source a new module? Or what Also is the module I got of the guy in England of no use to me?
    Do I need the module I pictured with a coded key ? Or do they have a coded key ?Thanks !
    54433802_577841986018248_6769455967072419840_n.jpg53910545_435490890526659_896973146328924160_n.jpg
    e32 750iL 1994 Calypso Red - Show Car
    e38 740i 2001 Titan Silver - Daily ///M Sport
    e39 540i 1997 MontrealBlau - Daily retired to restoration
    e34 525i 1995 Fjordgrau - Project
    e39 520i 1999 Diamond Black - Sold
  11. #36
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's an ultrasonic Alarm control unit - and not Alarm System 3 as I had fitted. If your car works without it then all's good!
    http://www.realoem.com/bmw/enUS/show...23#65758366229
  12. #37
    Feb 2016
    Northern ireland
    740i Sport
    Thanks Tim!
    That is what I like to hear haha
    Is the car disadvantaged in anyway because I have disconnected it? I've read that the OBC won't work without it, so I'm currently looking into possible solutions for that. But I'm wondering what the ultrasonic Alarm Control unit actually does, and what I'm missing out on without it
    Is there a key fob which comes with the car that is coded into the alarm unit? or what other was was there for me to stop the alarm from going off without taking the fuse out of the alarm unit?
    Sorry for all the questions!
  13. #38
    Feb 2016
    Northern ireland
    740i Sport
    Bought this for the e32 yesterday
    Much better than the boring English reg!
    53573905_567662207072167_4812346924856246272_n.jpgScreenshot 2019-03-20 22.27.05.png
  1. 1998 Calypso Red 750il Part Out
    By M7952 in forum 1995 - 2001 (E38)
    Last Post: 10-17-2019, 12:40 PM
  2. E32 1990 e32 750il $1500 whole car or parts drives great
    By e35m5csl in forum Whole Parts Cars
    Last Post: 12-27-2010, 10:35 PM
  3. E32 1990 E32 750il for sale...
    By Jubeisan in forum 7 series
    Last Post: 10-01-2010, 10:08 AM
  4. E32 feeler: my grey market e32 750il
    By AHenry014 in forum 7 series
    Last Post: 09-28-2010, 01:34 AM
  5. E32 1990 e32 750il $1499 drives great
    By e35m5csl in forum 7 series
    Last Post: 09-17-2010, 09:16 AM
