Results 1 to 2 of 2
Thread: Potential E92 328i Purchase
    Jan 2019
    Seattle
    None Yet
    I'm considering purchasing an 328i coupe and just have a few questions for you experts out there. This will be my first BMW, so I'd like to have as good an understanding as I can of just what I'm getting myself into. Any help would be greatly appreciated.
    Aluminum Bolts
    I understand most if not all of the bolts that screw into the engine block are made of aluminum in order to avoid corrosion with the magnesium block.
    • What are the main issues with these bolts?
    • How often do they break when being removed?
    • Do they always need to be replaced whenever they are removed?
    • Can replacements only be obtained from the BMW dealer?
    Water Pump
    I understand the electric water pump on these cars usually needs to be replaced every 60,000 miles or so.
    • Can replacement water pumps only be sourced from BMW?
    • Are there 3rd party manufacturers that offer a more reliable unit?
    Gaskets
    I understand it is common for the valve cover gasket, Oil Filter Housing gasket, and the oil pan gasket to fail on these cars. Do replacement gaskets hold up better than the factory gaskets or do these gaskets just need to be replaced every 40K miles or so?
    2010-2012 VersionsI know the E92 cars got a substantial update around 2010.
    • Were any of the common issues mentioned above addressed on those cars?
    • Were any new issues introduced with the update?
    Tools
    I know some of the bolts and fasteners are unique in BMWs. At a minimum what tools beyond a standard SAE/Metric tool set and torque wrenches would I need to acquire to perform the above fixes?
    Bellevue, WA
    335d, 328xd (had 330xi)
    Quote Originally Posted by automan25 View Post
    Aluminum Bolts
    Water Pump
    Gaskets
    Do they always need to be replaced whenever they are removed? - Always
    Water pumps don't always break at 60K. Many last 120K. You replace them when they break, with anything you want.
    I've never replaced a gasket, and I have 133K on my M57. Besides, you can add quite a bit of oil for the price of a gasket that leaks a quart every 50K miles.
    328i had no updates (N54 was replaced by N55 in 335i, but N52 wasn't changed much) other than head mods to fix a rattle due to lifter leak-down.
  1. Aftermarket Potential? E92 vs E92(M3)
    By Celsius in forum 2008 - 2013 M3 (E90, E92, E93)
    Last Post: 09-25-2006, 10:46 AM
  2. Evaluating a 328is purchase
    By turbosnow in forum 1991 - 1999 (E36)
    Last Post: 03-11-2006, 02:28 AM
  3. Help - '96 328i purchase questions?
    By Soon2bM3 in forum 1991 - 1999 (E36)
    Last Post: 07-13-2005, 04:45 AM
  4. Need a little advise on a 328i Purchase...
    By Mobjack in forum 1999 - 2006 (E46)
    Last Post: 04-14-2005, 10:59 AM
  5. possible 96 328i purchase
    By tommyh in forum 1991 - 1999 (E36)
    Last Post: 05-29-2002, 02:07 PM
