Results 1 to 8 of 8
Thread: 2nd Valve Cover Attempt
    Jan 2015
    US
    1995 bmw 325is
    3 weeks ago I completed the valve cover gasket replacement and the job went alot easier than I thought it would. There are no leaks along the cover except at the plug wells. Not as much as before the replacement but leaking in 4 wells none the less. I went with the Felpro gasket the first time and want to use a different brand this time around. Any suggestions would be helpful. Most say to stay away from Victor Reinz. How about the Malle brand?
    Oct 2003
    Seattle
    99 M3
    I use OE purchased online.
    Work in a circular pattern starting in the center when reattach the cover. Use fresh “doughnuts” or “ Rubber Seal” (15) 11121437395 for maximum ‘squish’.
    Jan 2015
    US
    1995 bmw 325is
    Quote Originally Posted by bluptgm3 View Post
    Where did you purchase the gasket set?
    Jan 2019
    Indiana
    318is, dodge ram
    The gasket brand wont vary in quality that much. Felpro should be fine. Did you torque it to spec? Valve covers will leak if you torque it to "feel". Also make sure the surfaces are extra clean (brake cleaner/paper towel) and you should be good with no leaks
    Apr 2015
    Tennessee
    1998 BMW 328i
    I get my parts from fcp Euro. Fast shipping, low prices, quality parts, and lifetime replacement. Best deal out there imo
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by innerbimmer View Post
    ECS Tuning but hard to beat FCP European warranty.
    Jan 2016
    Ca
    2001 525it
    Some times the whole cover needs to be replaced along with the gasket
    Jul 2005
    Indianapolis, USA
    1993 318i Touring
    Usually the reason for gasket leaks after replacement is that the original surfaces didn't get cleaned well enough. Did you get all of the "circles" around the plug wells nice and clean?
  1. Just got the valve covers regasketed 2nd time
    By JerrySS in forum 1995 - 2001 (E38)
    Last Post: 01-29-2010, 02:03 PM
  2. How to change valve cover gasket?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-10-2001, 12:12 PM
  3. anyone know where i can get a new valve cover??
    By mrdoenutz in forum 1991 - 1999 (E36)
    Last Post: 06-09-2001, 02:32 AM
  4. Painting Valve covers
    By KraZy007 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-15-2001, 11:28 AM
  5. Replaced valve cover gasket
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 03-11-2001, 03:08 PM
