RM European Auto Parts
Results 1 to 4 of 4
Thread: Major Issues
    Jan 2019
    Texas
    2014 328D
    Major Issues
    Hi, I am new here and need some help.
    The ignition push button is staying illuminated even with the hood, trunk and doors closed and the car locked. Key is 100' from car. Why is the button staying illuminated over 2 hours after locking?
    Also, the Auto Start/Stop at red lights randomly works.
    So far I have replaced the battery as the other got killed by power draw. Registered the battery with my Carly Pro adapter.
    I have now replaced the negative cable and IBS. Do you have to register a new IBS sensor with the car or it just picks it up?
    Still getting "Increased Discharge" and "Battery Discharging While Stopped / Electrical Devices Were Temporarily Switched Off".
    So today, I hooked up a multimeter to the positive cable and the positive post. I had the cable removed for this test.
    I am seeing 6.6 amps continually. I pulled every single fuse under the hood one by one and every fuse in the trunk next to the amplifier and every fuse on the REM. Pulled them all one by one. I could not locate the FEM to see if there were any fuses on it.
    The only aftermarket addition is HID lights. I pulled that fuse as well and it had no impact on pewer drain.
    No matter what fuse was removed, I never could get the car to stop drawing power. Car does not have comfort access I do not think.
    It will eventually go into self preservation mode and kill power to everything but still registers 1 amp and the ignition button will still stay lit.
    I'm lost. It obviously has to have something to do with the push button staying lit 100% of the time.
    I ran across this post about the EDC.
    https://www.m3post.com/forums/showthread.php?t=1283704
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the General BMW Discussion sub-forum. Help will be found here.
    88M3 AW 43k miles Project FS
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Hi Txfour, and welcome to the forum.
    You need to know that your car is a mass of computers. Carly really isn't going to do it for you.
    ISTA is BMW's own diagnostic system, and it has some special abilities. It can talk to the energy management system, and ascertain exactly which circuit has been sucking the electricity from your car after the car's supposedly gone to sleep.
    Don't try to mess with this "old school". Get the car connected to ISTA, and let the computers tell you what's keeping them awake. The system can tell you "Amplifier drawing unauthorized power, 256 times....et al...)
    By the way, when you do an old school drain test, hook up to the negative side, not the positive. Roll all the locks, and give it 30 minutes to fall asleep.
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    easy "old school" check
    An alternator with a failed rectifier can drain the battery in short order. Might want to try disconnecting the big red + wire and see if the draw remains.
    Your draw is pretty serious, I'd think the back of the alternator would be warm from dissipating that much energy.
  1. Major Issue With Nalley Bmw
    By RINGTAXI in forum Georgia sponsored by Harrison Motorsports
    Last Post: 05-16-2005, 09:53 AM
  2. Anyone ever had a clutch stop cause a major issue?
    By Chapel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-05-2005, 05:17 PM
  3. Is this a major issue (tread crack)
    By skidder in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-16-2005, 11:13 AM
  4. Car is having some MAJOR issues
    By '94 325is in forum 1991 - 1999 (E36)
    Last Post: 12-14-2004, 11:21 AM
  5. Wheel help major issue
    By sbkrider in forum 1991 - 1999 (E36)
    Last Post: 09-17-2004, 07:57 PM
