Results 1 to 10 of 10
Thread: S50/S52 Valve Springs
    Trussville, Alabama
    95 BMW M Techniq SCCA Ep
    Am adding S52 M3 cams to my M50 motor. Question is about valve springs. I know the S50/S52 springs (bee hive) springs and keepers will work, but how about the S54? Just happens that those are available Any help appreciated.
    Edit...should have been M54 springs.
    Oct 2003
    Seattle
    99 M3
    Be sure your cam boxes are proper configuration.
    I suspect the height is incorrect.
    Trussville, Alabama
    Cam boxes are the same part number.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Chuck Baader View Post
    Not what I see in www.realoem.com
    S52 Cam Tray
    Bearing Ledge E 11 12 1 436 224
    Bearing Ledge I 11 12 1 740 428
    325 Cam Tray
    Bearing Ledge E 11 12 1 744 144
    Bearing Ledge I 11 1 21 744 141
    Trussville, Alabama
    I stand corrected...was going on what I was told. But, these numbers were superseded as follows:
    All of the above numbers default to a 11 12 1 744 141, for these cars: 3' E36   (11/1989 — 10/1995)
    5' E34   (01/1989 — 06/1996)
    So, they are all the same.
    Oct 2003
    Seattle
    99 M3
    Look at the date range of those interchanges
    M50 cam trays (bearing ledges) do not interchange with 1996+ S52 CT/cams - 325/M50 Cam Tray/Bearing Ledge I 11 1 21 744 141 and
    While other part numbers are listed as being superseded the 1996+ S52 Cam Tray/Bearing Ledge I 11 12 1 740 428, in the view of realoem I’ve been looking at are not listed
    http://www.realoem.com/bmw/enUS/part...&q=11121744141
    Nor does 325 Cam Tray/Bearing Ledge E 11 12 1 744 144 interchange/supersede 1996+ S52 Cam Tray/Bearing Ledge E 11 12 1 436 224
    In this view of realoem-
    http://www.realoem.com/bmw/enUS/part...&q=11121744144
    Are you accessing a different/more accurate database?
    S50/S52 trays appear to be the same, which I did not believe to be the case-
    http://www.realoem.com/bmw/enUS/show...diagId=11_6081
    Sent from my iPhone
    Trussville, Alabama
    I have been told that the later cams with more lift/duration can be used in the earlier tray but the trays must be ground for clearance. Next week I will be able to get both in my hands with a pair of M3 cams to check.
    Trussville, Alabama
    Ok, I have the proper cams and trays for the conversion....question now is m54 valve springs???
    Oct 2003
    Seattle
    99 M3
    Check part numbers in www.realoem.com for part number compatibility.
    Trussville, Alabama
    Have....they are different part numbers but both are bee hive.
  1. upgrade to s52 valve springs (from s50)?
    By dipstick in forum Forced Induction
    Last Post: 01-12-2009, 08:41 AM
  2. (6) S50/S52 Valve Springs - only 47k miles on them
    By BSH in forum Engines, Performance Parts & Software
    Last Post: 02-10-2008, 10:09 PM
  3. FS (6) S50 Valve Springs, (12) S52 Valve Springs and S52 Retainers
    Last Post: 02-10-2008, 10:00 PM
  4. WTB: m50 S50 S52 valve keepers
    By dinno246 in forum BMW Parts Wanted
    Last Post: 12-14-2006, 07:52 PM
  5. s52 valve springs
    By propr`one in forum BMW Parts Wanted
    Last Post: 05-22-2006, 09:06 PM
