Results 1 to 5 of 5
Thread: New to Bimmers Need help info
    Jan 2019
    Bennington vt
    1989 BMW 750il
    Greetings everyone,
    I just bought a 94 740il. Car made it home to Vermont from Connecticut, but it developed two problems along the way and a third I noticed after I got it home.
    1. Coolant leak from the front of the engine. Appears to be more to the passenger side. If it turns out to be the seals on the internal coolant pipes, how long of a job can I expect that to be? And what is the most common leak from that area? I'm hoping it's not major.
    2. Car idles low and revs fine, but when you let off the gas, it stalls. You have to start it with your foot on the throttle slightly, then let off easy after it starts otherwise it stalls.
    And 3. While looking around under the hood after I got it home, I found the PCV is not connected. It is blocked with electrical tape and there is no hose or tube anywhere that I can find that goes to it. Where is the engine end of the PCV? Maybe that is the cars idle problem?
    Thanks in advance for all help.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    with regards to the coolant leak read this https://www.bimmerforums.com/forum/s...2-Coolant-Leak Hidden-M60-M62-Coolant-Leak
    I am not the M60 specialist and cannot tell how long the repair takes. Idle problem could be the not connected PCV, fix that first
    ETK is here with drawings http://www.realoem.com/bmw/enUS/part...-E32-BMW-740iL
    Jan 2016
    Ca
    2001 525it
    Below the intake manifold are the pipes, below the pipes is the valley pan gasket. Remove the intake manifold, replace all the seals, front throttle body gasket and the pcv plate on the back of the manifold. Check the pops when you remove them for corrosion around the oring sealing area and replace the valley plate. I'm trying to picture the hose that is not connected to the pcv plate, I don't have an answer for that
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Here's the information on the PCV:
    https://www.meeknet.co.uk/E32/PCV/Index.htm
    ...and more info on the V8's:
    https://www.meeknet.co.uk/e31/BMW_M6...2TU_Engine.htm
    My BMW Repair YouTube Channel
    Jan 2019
    Bennington vt
    1989 BMW 750il
    Thanks for the help all.
    So far I replaced some of the upper hoses that used to go to the heater core. {has been bypassed due to leakage} then refilled the system with fresh coolant filling the radiator and the block from the upper radiator hose, then completing it in the expansion tank.
    Drove it around town all afternoon yesterday and so far no leaks.I don't know how that would have affected the front of the engine leak, but it appears to have stopped for now.
    It still has the idle problem. Haven't had time to thoroughly hunt that down yet. But there is definitely a plugged spot on the PVC and I simply cannot find a hose or tube that matches that floating around. Getting a pounding with snow this weekend so I probably won't do much till later this week.
    Again, thanks for the help and I'll be around. I have a project {beater} 89 750iL that I hope resurrect. That car needs considerable work to make it a driver again. Starting with a fuel leak from behind the left rear tire {only when the key is on} and breaks.
  1. New to Bimmer need help
    By jvz550i in forum 2004-2010 (E60,E61)
    Last Post: 09-19-2012, 09:49 PM
  2. New to Bimmers, Need repairs, Please Help!!
    By cypher78 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-21-2009, 03:37 PM
  3. new to bimmers need help
    By cruzstyle in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-07-2008, 02:45 AM
  4. looking to seal the deal, new to bimmers..need some help
    By dlee427 in forum 1999 - 2006 (E46)
    Last Post: 03-19-2007, 02:53 PM
  5. New to bimmer need Extended warranty...HELP.
    By texbeamer in forum 1995 - 2001 (E38)
    Last Post: 01-27-2004, 12:11 AM
