Results 1 to 14 of 14
Thread: Windshield wiper wont return to home position Tried everything
    Indiana
    2001 740i M sport Imola
    Hi Gents. So I've tried everything. Replaced wiper relay, still doesn't work properly. There is no condensation or any corrosion below the connector or on wires, everything is in tact, no blown fuses. The linkage seems to want to flex slightly downward before twisting two more times and will not run correctly. I am puzzled at this point. From the days I've spent trouble-shooting this, it can only be the wiper motor being faulty or the general module. Not sure which to try next. It started up as soon as the snow hit. I can get the wipers to wipe back and forth on higher settings just fine but they won't return home. Washer fluid works just fine. I do have a spare linkage but I don't think that is the issue. What would you guys try next? This is driving me nuts! Ive tried adjusting the wipers but it won't do anything. I am clueless at this point.
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    I remember reading in the WDS that there is a microswitch that tells the wipers when they are in the home position. That switch may be bad or misadjusted in yours. I don't know where exactly the switch is, though. It may be in the motor.
    '98 740il | 9/97 build | schwarz 2 | sandbeige | 5AT | 270k
    '04 330i ZHP sedan | Mystic blue | Alcantara | 6MT | 120k
    '00 540i sport | Titanium silver | Black | 5AT | 152k
    '85 Mustang GT convertible | Medium charcoal metallic | Gray | 5MT | 216k | one owner, all original
    mods: m-pars | Bilsteins & B&G springs | ValentineOne | StealthOne
    retrofits: full nav | MKIV | bluetooth TCU | BM53 w/ AUX input | video module w/ AV input & backup cam | oem sirius xm | xenon | shades | PDC | rain sensor | BMW DWS TPMS | lighted door handles | front seat heaters | heated steering wheel | euro rear fog lights | ski pass | folding mirrors
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Do the wipers always return to the same position on the windshield when they stop?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    The park switch is indeed in the wiper motor:
    https://www.newtis.info/tisv2/a/en/e...-motor/kmnRCTV
    Indiana
    Thanks. I did see this thread and wondered if the "grease" is the issue. I did open it up once and there is alot of grease in there but I'm hesitant to wipe a bunch of it out of there. Not sure where it belongs and where it does not belong. There is a small metal clip inside, I wonder if that is the "switch?"
    https://www.bimmerforums.com/forum/s...-faulty-wipers
    Indiana
    park
    Quote Originally Posted by clarkitect View Post
    Yes they do.
    Apr 2014
    PA
    This might sound weird but, on my e36 318TI I had a similar problem. Wipers would not return to home and sometimes would "park" in different positions. I bought a Bosch wiper motor to replace mine as the park microswtich is in the motor. Turns out when I pulled the linkage and all from the cowl, the linkage was loose on the splines of the motor.With 215,000 guess its possible Tightened the linkage and it worked and parked fine. I replaced the motor anyway and all is well
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
    Indiana
    Thanks for the replies. I've pulled this thing apart and reinstalled it probably 6 times now and cant get it working. I think I'm going to order the motor and see if that solves it. If not then I'm going to hand it over to the mechanic.
    Indiana
    I pulled off the plate, cleaned out all the excess grease, wiped everything clean, problem remains. Im going for the motor now, if that doesn't work, I'm handing it over to my mechanic. Hoping it isnt the general module.
    Indiana
    So after 2 and half weeks of mystery, and being sold two bad wiper motors (one by a parts yard, one by JC whitney) I have finally found the issue and fixed the positioning. It was the hinge anchor positioning. Somebody did post this in a previous thread, and I did try a few different positions before with no luck, then last night after installing the last bad motor I figured it out. You have to position the hinge connection as shown with the rod facing east. This should be noted in some of the stickies and on E38 but I didn't find it anywhere.
    So moral of the story was the hinge screw came loose, the anchor hit the wrong position, I tightened it up and was left with the issue. Finally fixed!
    And took the time to install this rubber cowl fix for the lower windshield that I bought a year ago but hadn't got around to installing. So far so good.
    https://www.ebay.com/itm/BMW-7-Serie...mgwf:rk:2:pf:0
    Jan 2006
    Ft. Lauderdale, FL
    Thanks for posting back and glad it is fixed! I bet this will help someone in the future!
    Rutland, Vermont
    Yeah thanks for closing it out. Good to find these kind of threads down the road.
    Oct 2013
    Brunei Darussalam
    2002 BMW X5 4.6
    On a slight different issue and i do sincerely apologize.
    I appreciate any assistance render here. Just need to know what is the BLACK item on this Wiper linkage rod call/name and whats the part number, for
    BMW X5 3.0si M53 2003 RHD. Photo attached.
    Mine has broken and its like going through hell searching high and low in google but cant find any.
    Regards
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Looks like BMW wants you to buy the whole assembly.
    https://www.realoem.com/bmw/enUS/sho...diagId=61_1342
  1. Windshield wipers wont stop !!!
    By nphunter55 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2009, 08:42 AM
  2. 98 318i windshield wipers wont work
    By squeak211169 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-10-2008, 01:47 PM
  3. My wipers wont stop in off position.
    By cyb0rg in forum 1991 - 1999 (E36)
    Last Post: 03-22-2005, 06:28 PM
  4. Windshield wipers wont work, any one have any tips on what to check?
    By jai2004 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-21-2004, 12:45 AM
  5. windshield wipers wont stop
    By SweetNLo in forum 1991 - 1999 (E36)
    Last Post: 04-13-2004, 01:46 AM
