Results 1 to 7 of 7
Thread: 1995 BMW M3 Turbo?
    Jan 2019
    Raleigh, NC
    1995 BMW M3
    1995 BMW M3 Turbo?
    Just bought a 95' M3 with 230k miles. Car runs and drives good but can hear the lifters ticking. I wanna get it up to at least 400 hp. Any recommendations? Would I need need a rebuild to add a turbo and get that power without blowing out the motor or is there another way to do it?
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by e36.s50 View Post
    400hp is readily achievable.
    Something like a spa manifold, 3” intercooler, and gt30r/35r would get you there.
    I can set you up with a chip to run the turbo on your cars electronics.
    Pm me if you want more info.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Try changing to a heavier weight oil and see if the noise goes away. There is a link in this subforum for tried and tested setups. As Vollosso said, SPA T3 manifold, GT35r, 42lb injectors, 44mm wastegate, 803 MAF, 12x24x3 intercooler, CES headgasket/arp studs and you're golden.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Apr 2006
    Minnesota eh?
    86 325es
    When you are ready to build it I would recommend that you pull the head off with the motor in the car, clean up the block and head surfaces, and put in the CES cutring and copper spacer headgasket to lower the compression. At the same time you can put in a new set of lifters and also install the turbo manifold before you put the head back on, which will save you a lot of aggravation.
    Mar 2015
    Vancouver, BC, Canada
    2014 Alpina B7
    As you can tell from the previous posts, definitely get a CES headgasket combo. 400whp+ is super easy on these motors.
    Jan 2019
    Raleigh, NC
    1995 BMW M3
    What about the high mileage? would it handle it?
    Mar 2015
    2014 Alpina B7
    I’d drop the pan and inspect the rotating assembly as good as I could and also check the head and cylinder bores for wear. As long as the tune is good (RK-Tunes is the best), the engine should handle, although the mileage is a little to be honest.
  1. E36 1995 bmw m3 turbo $7,900
    By M3Power1 in forum 3 series & Z Series
    Last Post: 10-13-2010, 01:22 PM
  2. FS:1995 BMW M3 TURBO Built & Previously owned by Diogo Azevedo
    By 99turboazevedo in forum 3 series & Z Series
    Last Post: 08-19-2007, 01:18 PM
  3. 1995 BMW M3 TURBO..Needs Work..please read..asking 17k$
    By 99turboazevedo in forum BMW Cars For Sale / Wanted
    Last Post: 07-17-2007, 12:24 PM
  4. 1995 BMW M3 TURBO..Needs Work..please read
    Last Post: 04-15-2007, 12:43 PM
  5. Feeler: 1995 BMW M3 Turbo
    By FknFast///M3 in forum BMW Cars For Sale / Wanted
    Last Post: 02-22-2005, 02:19 AM
