Results 1 to 10 of 10
Thread: Brake Booster Blues
    Jul 2017
    austin, tx
    1979 e21
    Brake Booster Blues
    installed reconditioned booster, and a new mc. worked great for about 20 miles, then got the stiff pedal with lousy braking.
    does anyone have a spare booster that i can try, to diagnose this?
    i'll pay shipping.
    Houston, Tx
    '78 320i
    Are you certain you seated the MC seal proper on the brake booster?
    Jul 2017
    austin, tx
    1979 e21
    there is an o-ring in there. i don't see how you could improperly seat it. the mc sits tight against the booster when tightened, no gap. i guess i could order another one and try it.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    That could be the brake booster one way check valve has gone kaput--cost a few bucks-test it
    Randy
    Jul 2017
    austin, tx
    1979 e21
    tested it. air cannot be sucked towards booster
    Nov 2007
    Cool
    check the hoses going to the brake booster check valve and from, I run a dual brake booster check valve set up, one check valve 1/2 way and one in the brake booster-- I had a problem once of stiff brakes--vacuum leak -hose clamped to throttle body connection was cracked, sliced off the split hose ends back to normal.
    Randy
    Aug 2018
    Battle Ground, WA
    83 e21 82 E23 80 E12
    I have a used booster thats in fair condition and also a booster thats in great condition. Both have what look like new master cylinders too if interested.
    Jul 2017
    austin, tx
    1979 e21
    i'll fuss with it some more
    Dec 2012
    topanga CA
    84 728i,325Ci, 77 R100RS
    [QUOTE=mtbmx;30185574]installed reconditioned booster, and a new mc. worked great for about 20 miles, then got the stiff pedal with lousy braking.
    Is the pedal maybe stiff because the brakes are dragging and everything's hot?
    Are the brakes OK again when cold/pressure bled?
    20 miles is an odd amount of time for a second booster to fail.
    Jul 2017
    austin, tx
    1979 e21
    it rolls easilly. does not feel like they are dragging. bled brakes again, nothing changed. i'll try another mc o-ring and a check valve
  1. Replies: 11
    Last Post: 05-10-2015, 03:34 PM
  2. E36 WTB Brake booster sensor end cap - BLUE
    By K1118 in forum BMW Parts Wanted
    Last Post: 11-05-2012, 12:57 AM
  3. Can i tap into my brake booster for my boost gauge line?
    By hamann1000 in forum Forced Induction
    Last Post: 06-10-2003, 07:53 PM
  4. brake booster sensor thing !
    By Dj Waffelz in forum BMW Parts For Sale
    Last Post: 01-02-2003, 02:46 PM
  5. Upgrade master cylinder of brake booster
    By TYE in forum 1992 - 1999 M3 (E36)
    Last Post: 12-09-2002, 02:24 PM
