Has anyone discovered the BMW part number or found a source for the Joint Sleeve (see attached image) used in the US headlight adjuster thimbles?
I have a few that came with the original headlight kit, however it takes 6 to replace a set in both headlights
So far the E31 community has prototyped the thimbles and adjuster wheels, etc. but I have yet to see replacements identified for the joint sleeve used for the OE thimbles.
I tried to order the Joint Sleeves listed under the Euro headlights just to check if one of those will work but BMWNA is blocking the order of non-US parts.
63 12 1 392 066
63 12 1 386 616
