Results 1 to 3 of 3
Thread: Heater/AC Not Working
    Jul 2018
    Georgia
    1992 BMW 735IL
    Post Heater/AC Not Working
    Hello,
    I have a 1992 BMW 735IL which has 425,000 miles on it. My car started to run hot and I would have to add coolant to it daily. I replaced the thermostat, water pump, and the fan clutch. I did bleed the system and the car is still running hot.
    The heater and ac stopped working before I replaced those items I listed.Do I need a blower motor resistor, if so where is it located?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    First of all bleed the system http://www.nmia.com/~dgnrg/page_19.htm
    You had to add coolant daily? Was it leaking outside because of leaking hoses or did it get into the engine = grey, sweet smelling smoke came from the exhaust? If so, then you might have a headgasket problem.
    Pull the 3 wire connector from the heater valve, the heater valve should be fully open without power and the heating system should work. If not, not enough coolant or the heater valve is stuck closed. Heater valve you can disassemble and clean, see my website below.
    The E32 does have a socalled heater sword, that only regulates the blower fan speed. But not the temperature. http://www.bmwe34.net/E34main/Mainte...ical/Sword.htm
    The sword is located on the right side/passenger side, shown here on a RHD E32 http://www.meeknet.co.uk/E32/Microfilter/Index.htm
    AC system you have to check if there is enough pressure in the system, otherwise it will not work.
    Jul 2018
    Georgia
    1992 BMW 735IL
    Thank You!!! I didn’t see any leaky hoses. I would add coolant and then the next day the add coolant indicator would come up. The temperature gauge would still be at normal operating level. After 4 days of this, it started to run hot that’s when I repacked the items that I listed. I will get to work!!!
  1. AC/heater fan not working?
    By Dat Aus in forum 1996 - 2003 (E39)
    Last Post: 02-25-2011, 11:19 AM
  2. Heater/ac not working
    By max2moon17 in forum 1996 - 2003 (E39)
    Last Post: 12-13-2009, 10:54 AM
  3. AC/Heater blower not working 1992 325I
    By porto35 in forum 1991 - 1999 (E36)
    Last Post: 08-29-2007, 10:03 PM
  4. climate control fixed and ac/heater still not working!!
    By MRMARSH in forum 1992 - 1999 M3 (E36)
    Last Post: 12-08-2006, 05:08 AM
  5. AC/Heater Fan not working and other few questions
    By seb928s in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-15-2005, 10:38 PM
