Results 1 to 23 of 23
Thread: Light Adjuster Fix, but , can't open unit
    May 2014
    Netherlands
    E39 2003 525i Touring
    I wonder form which year Hella changed their headligth units, from be able to disassemble , to the ones which are fixed unit and can not be open?.
    My units show date 11-02 (november 2002).
    I manage to get the old adjuster of but was not able to open none of both unit.
    I tried heatgun, and also oven (5 minutes , 200 gr C )
    Adjusters I need are this type
    No idea if the ones which are installed inside the units which you can not open are different.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    I believe you have the non bake open type of lenses. See "ship in the bottle" approach. It is not that hard.
    DIY LINK: https://www.bimmerforums.com/forum/s...t-(no-cutting)
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    later models can not be opened do to the adhesive used. I did the "contortionist" method. It took a few hours per unit but they work fine now. Unfortunately, you cant clean the inside of the lenses but so be it.
    Aug 2013
    Finland
    1999 540i M-sport
    Black top little cover = You screwed that's basically all you need to know
    You have those, just cut holes around where adjusters are, and then plastic weld all back.
    Lähetetty minun ONEPLUS A5010 laitteesta Tapatalkilla
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Loved the "contortionist" method +1!!!
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Apr 2018
    Socal
    00 528i, 01 540i
    Ship in the bottle method is do-able. Just takes patients and some picks/weird angle tweezers or dentist tools if you got them.
    May 2014
    Netherlands
    Thanks, I think I really have the latest kind.
    Will for sure look at all given solutions.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    July 2002 was when they switched to urethane. I cut the lenses out, clean out the channel, fix the adjusters, clean the projectors, apply the new butyl rubber into the channel, pop the new lenses on to the housing, good as new again.
    May 2014
    Netherlands
    So you used new lenses...OK.. I think I will first try to do the "back" way
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    Thankfully mine are bakeable. If they were not, I would just use the method that cuts a hole in the housing immediately above each adjuster, making replacement very easy. Then just make sure you seal the housing when replacing what you cut out.
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    07/02 aka July of 2002 is when the adhesive was switched over. Your lights are non-bakeable I highly recommend the ship in a bottle approach or if you've got $$$ buy a pair that are bakeable and replace the adjusters on them preemptively.
    2003 530i M Sport [Black Sapphire Metallic & Sand Interior]
    IMG_1075 by Alex Wilson Photography, on Flickr
    Mar 2012
    Hayling Island
    Alpina B10
    Just replaced my adjusters this week from the back, luckily UK lights have a removable cap on top of the lens which makes it more doable. Still took some patience but a cheap set of forceps and a long T15 screwdriver really help.
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    I needed a T-10 torx screwdriver which is at least 4 inches long to do my non-bakeable headlights
    May 2014
    Netherlands
    Mine has also a removable cap on top. No idea what this cap is for, but I will try to use it.
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by seninnha View Post
    Under the cap there should be light regulator, for example if you are in France, and go to UK,where it is RHD, and lights are different, you switch lights under the cap, and they become more even,and don't blind everyone.
    May 2014
    Netherlands
    Ok, thanks.Good to know.
    Lawrenceville, GA
    4 BMWs.
    Quote Originally Posted by nike32 View Post
    What do you mean by "black top little cover"?
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by amancuso View Post
    On top, little black cover
    Lawrenceville, GA
    4 BMWs.
    O, ok. Mine look like this on top.
    Aug 2013
    Finland
    1999 540i M-sport
    Those should come apart, I believe.
    May 2014
    Netherlands
    OK, I manage to repair my adjusters.
    Unfortunately I was not able to get the old out or new in through the back of the unit.
    Therefore I made a hole on top of both units, just above the engel-eyes.
    After I did that, I was able take the old adjusters out, and install the new one without any problem.
    Took me about 32 hours in total for both units. When I was done I cover the hole with a piece of black plastic and glue it on.
    Once installed in the car, you hardly see that units where cut open.
    As both units were out of the car I also tackled both front covers.
    Instead of polish them , I sand them down with 600 grit sandpaper and then give them a coat of 2K clear coat.
    results
    Very happy. Finally is this done.
    Nex thing will be to get more info about LED lights.
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    results
    Looks great. I just question the durability of the clear coat.
    May 2014
    Netherlands
    Well, it's the same coat people use when painting their car, so i guess it should last.
    Will see.
    Can always sand them down and do a polish
  1. SRS light fix for when asc control unit is completely removed?
    By Jean-Claude in forum 1992 - 1999 M3 (E36)
    Last Post: 06-19-2006, 01:20 AM
  2. Replies: 7
    Last Post: 10-22-2003, 08:37 PM
  3. car won't start after brake light circuit fix
    By dmw in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-20-2002, 02:29 PM
  4. car won't start after brake light circuit fix
    By dmw in forum 1992 - 1999 M3 (E36)
    Last Post: 10-20-2002, 02:28 PM
  5. install city lights and fix xenons !
    By Changster in forum 1992 - 1999 M3 (E36)
    Last Post: 07-31-2001, 02:59 PM
