Results 1 to 6 of 6
Thread: Radiator Clips
    May 2018
    Red Deer, AB, Canada
    1995 BMW 320I Sedan
    Radiator Clips
    Hi, I replaced my radiator fan and to do so I needed to take off the radiator. Doing so I broke both the mounting clips on the top (I'll put a picture of them if you don't know what I'm talking about). I was wondering if you can drill holes to use bolts to mount the radiator instead of those stupid clips.
    Jan 2016
    Ca
    2001 525it
    Just buy new clips
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    E36 radiator stay made of alumuinum, $55 http://rebooteng.com/parts/e36-radiator-stay/
    This part replaces the factory plastic hinged radiator brackets for BMW E36 chassis which commonly break. This kit includes everything necessary to replace both OEM radiator stays. All machined parts are made of 6061 Aluminum with stainless steel hardware. Each stay is a two piece assembly that clamps onto the core support.
    Oct 2012
    washington, dc
    96 E36 Vert 03 E39 M5
    Quote Originally Posted by jclausen View Post
    Just buy new clips
    Agreed : drilling holes for no good reason : path to ruin . Just fix it correctly
    http://www.bmwmregistry.com/detail.php?id=13792
    * E39 M5 SterlingGray -RIP 11/2018
    * E36 328 vert Schwarz - ~TurboProject underway
    * E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
    Mar 2013
    THE DIRTY THIRD
    '95 M3
    Quote Originally Posted by shogun View Post
    I have those, they are awesome.
    Turbo E36 M3 with all the things..
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I took some aluminum bar stock — maybe 1”X3” and bent it into an L shape. The end of the L went into the The stock into the radiator slot. I drilled the long end and screwed to the front sheet metal. Has worked well for 10 years.
  1. Quick question....mid-install....radiator clips? How the heck to get them loose
    By Phanta-Z in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-29-2004, 05:28 PM
  2. Need some PN's (Radiator Clips and Inner rubber shift boot)
    By 97 MPWR in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2004, 07:55 AM
  3. Radiator Clips
    By guc32 in forum Forced Induction
    Last Post: 03-22-2004, 12:18 PM
  4. quick help: removing radiator clips
    By LTrain in forum 1992 - 1999 M3 (E36)
    Last Post: 11-08-2003, 10:04 PM
  5. How do you get the radiator clips off?
    By 96m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-16-2003, 08:18 PM
