Results 1 to 6 of 6
Thread: trunk issues - confirmed and solved
    Jan 2019
    Seattle, WA, USA
    2009 BMW 528i
    trunk issues - confirmed and solved 2009 528i
    Joined this forum to ask about trunk problems on a [new to me] 2009 528i - battery drain, lights stay on, actuator engages spontaneously, false license lamp messages, etc.
    Read a few posts here about broken wires at the hinge. Opened mine up tonight to find the exact thing I read here - broken brown (ground?) wire. Textbook example.
    I pulled the inner trunk lid liner, unclipped the harness so I could slide it out of the hinge enough to repair. Soldered and shrink wrapped the one broken wire, then added some corrugated plastic sleeve around the entire harness. I left out the rubber plug usually at the end of the hinge - that looks like the source of the problem to me - guarantees the wires will bend at a 90 degree angle every time opened/closed. By leaving the plug out and using the plastic sleeving I believe the wires will take a more natural bend, and will be protected from rubbing on the hinge tube.
    Mar 2008
    Napa, Ca
    1987 M6
    Nice little fix. Kudos !
    José
    1987 M6
    Livin the dream!
    Sep 2008
    Brentwood, CA
    2000 528iT; 2008 550i/6
    I hope you scrutinized all the other wires in the harness as I'd be surprised if only the brown wire was affected. Th brown may have been broken but I'm guessing the others were likely stressed and may not be far behind. Good luck.
    2007 530i sport (Montreal Blue w/ gray interior)
    2008 550i sport (Alpine White w/ black interior)
    Jan 2019
    Seattle, WA, USA
    2009 BMW 528i
    yes I stretched and bent the other wires looking for other breaks. Typically if the copper is broken the insulation will stretch if you pull on the wire. The brown wire appeared to be the only culprit - and being broken and contained within the wire tape - it was certainly making intermittent connection and acting randomly.
    Speaking of wire tape - what the hell is that sticky stuff they used? I still have residue left on my hands!
    Jan 2016
    Ca
    2001 525it
    I repaired my old Volvo wagon with wire that they use on the robots that they for building cars. The wire as a very fine diameter but the flexablitly comes from the fact that the wire core is not just one. It Is a bunch of individual cores of wires that make up the whole wire.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by jclausen View Post
    Typical automotive wiring is multi conductor.
    How is robot wire different?
  1. Will this hold up? Trunk issue.
    By segue007 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-17-2005, 04:52 PM
  2. trunk issues!!!
    By SHEBUILT in forum 1976 - 1989 (E24)
    Last Post: 04-01-2005, 09:00 PM
  3. Trunk issues
    By cougar in forum 1991 - 1999 (E36)
    Last Post: 11-04-2004, 07:57 AM
  4. Having a trunk issue... Please help
    By skorpiond in forum 1988 - 1996 (E34)
    Last Post: 11-01-2004, 07:26 AM
  5. Keyless Entry / Trunk Issues
    By fldragon in forum 2001 - 2006 M3 (E46)
    Last Post: 09-17-2004, 09:46 PM
