RM European Auto Parts
Results 1 to 10 of 10
Thread: Will this temp fix work on oil separator hose?
    Jan 2019
    Texas
    2001 325i
    Will a gorilla duct tape temporary fix work on crankcase vent hose?
    I broke it in half where the ribbed part starts when I was changing the valve cover gaskets, so it’s kinda got a packman mouth. Will duct tape work until my ccv replacement kit comes in the mail? I gotta drive an hour away and back in the next 2 days. 2001 325i
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    You’ll likely end up with a massive vacuum leak and codes P0171 & P0174.
    Jan 2019
    Texas
    2001 325i
    What if no codes popped up? I drove it around for 30mins with the duct tape and it was driving the same. What are the symptoms of a vacuum leak? Also is the hose pressurized?
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    i wouldn't be too worried about it, actually. i did the exact same thing on my car during a VANOS replacement - i think that's when that hose broke due to age/being brittle. this is the hose that's right at the top front of the engine and it has a 90 degree connection into the valve cover, yes?
    i think i actually used electrical tape.
    vacuum leak could produce rough running, etc. that hose is pressurized but (if things are working correctly) it's a very slight pressure - almost imperceptible....
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by shadowpuck View Post
    OP is in Texas, so duct tape.
    Mar 2003
    St. Joseph, Mo.
    ahhh, so just like speed tape at the track! haha......
    Jul 2004
    Houston, TX
    36 Cylinders
    Duct tape gets very soft and quickly loses its ability to hold things together in heat.
    You can use aluminium HVAC tape for a quick temporary fix, until you get a new tube.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Just wanted to point out that "temporary" should refer to the amount of time it takes for the new one to get to you....this is a very inexpensive part, and it should be replaced right away.
    https://www.ecstuning.com/b-rein-par...611432559~ren/
    Chris Powell
    BMWCCA 274412
    Jan 2019
    Texas
    2001 325i
    Thanks everyone, I drove it and the gorilla duct tape held up but definitely couldn't last more than a day of commuting. I got hvac tape on it now and I just ordered a ccv replacement kit, as soon as it gets here I’m replacing the whole system. Y’all are quick on this forum.
    Jun 2002
    E39M5, E500 4WD
    Welcome to the forum, Morty. We're here to help.
    Chris Powell
    BMWCCA 274412
  1. 3' E36 323i Crankcase-Ventilation/oil separator hose clamp delete
    By Lordniksidor in forum 1991 - 1999 (E36)
    Last Post: 06-14-2016, 12:11 AM
  2. Replies: 0
    Last Post: 09-30-2015, 09:57 AM
  3. Oil temp not working
    By Maxa5 in forum 1988 - 1996 (E34)
    Last Post: 06-27-2014, 11:27 AM
  4. E36 Used PCV/CCV or oil separator + hoses
    By Estrader in forum Engines, Performance Parts & Software
    Last Post: 02-08-2013, 02:33 PM
  5. rich328: Your xenon OBC fix worked on my car as well!
    By 99M3 in forum 1991 - 1999 (E36)
    Last Post: 10-05-2001, 08:44 AM
