Results 1 to 25 of 30
Thread: 1990 e32 wont start after charge of battery HELP
    Jan 2019
    Boston Ma
    1990 BMW 735il
    I have a 1990 e32 it was driving fine a purchased it about 10 months ago got a couple thousand miles added to it since I dis a tune up with a guy that I guess didn't know fully what he was doing I'm not sure if the plugs had to be gapped or not but it had a miss fire that I was sure a tune up would fix anyway it was running a bit ruff I parked it for the winter started it one a week a couple weeks in and now it wont start its driving me crazy please help I don't want to give up
    Last edited by shogun; 04-25-2019 at 11:17 PM. Reason: trying to fix the video, did not work
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Test your battery.
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    It won’t crank or it cranks and won’t start?
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    yes, we need more details. Does it crank or not? Is the fuel pump running and pumping?
    Do you get sparks?
    Basically all this: https://www.bimmerforums.com/forum/s...power+ultimate
    Jan 2019
    Boston Ma
    1990 BMW 735il
    It cranks now that I took the battery to be tested and charged it is getting fuel had a guy test the fuel line it cranks but doesn't fully turn over to start
    Jan 2005
    Japan
    What are the test results of the battery? You can also set the ignition on and then check on the OBC under test #9 the voltage http://bmwe32.masscom.net/johan/obc_...c_secrets.html
    But that only shows you the voltage without load. Did they make a load test of the battery?
    Looks like the battery is bad.
    Get another car and use a jumper cable to battery B+ post in the engine bay amd to chassis and use that car to start your engine. Or: To hook up jumper cables, park the donor vehicle next to the vehicle with the dead battery, turn both vehicles off, and set the parking brakes. Next, clamp one of the red clamps onto the positive terminal of the dead battery, then secure the other red clamp to the positive terminal on the donor battery.
    https://www.dummies.com/home-garden/...p-start-a-car/
    Jan 2019
    Boston Ma
    1990 BMW 735il
    The battery has been tested good��
    It cranks but wont start
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Give it a jump test battery still not working
    Jan 2005
    Japan
    Enough fuel in the tank? Does the fuel pump work at all?
    Spark plugs, plug wires, rotor & ignition coil - Clean and inspect
    Distributor cap – if eroded and worn - changed to new one
    Check fuel pressure . Might need to replace Fuel Pump and fuel filter.
    check fusible link near battery http://www.bimmerboard.com/forums/posts/377728/
    checked all fuses in engine bay and under rear seat
    Do you have a fault code reader like a Peake tool?
    or do a stomp test
    https://www.bimmerforums.com/forum/s...e-pedal-faults
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Shogun need help could it be the timing chain
    Shogun need help, could it be the timing chain?
    Oldham UK
    '00 330i Sprt '92 525i
    When you fired it up last time, how long did you run it for?
    Jan 2005
    Japan
    Timing chain I do not believe, that lasts very, very long. Check all the items listed above we asked you and reply in detail.
    Jan 2019
    Boston Ma
    1990 BMW 735il
    The last it started
    Quote Originally Posted by whiskychaser View Post
    I started it right up and it run for 25-30 minutes
    Is there a video on how to do the stomp test as I don’t understand how
    Jan 2005
    Japan
    google for stomp test bmw e32. Here some more info https://www.bimmerforums.com/forum/s...e-pedal-faults
    1) Turn the ignition switch to the 'engine run' position. (do not start the engine)
    2) Depress the gas pedal to the floor 5 times.
    The CHECK ENGINE light will blink out the FAULT CODES starting with the lowest number first. These FAULT CODES consist of 4 digits each separated by a short pause (ie. blink pause blink blink pause blink pause blink translates as 1 2
    http://www.e38.org/e32/bmw%20code%20defaut.pdf
    did you meanwhile check the fuel tank? We recently had another member which had a no start problem and it finally turned out that there was not enough fuel in the tank.
    Jan 2019
    Boston Ma
    1990 BMW 735il
    No sir it currently has a lot gas
    It was a lot of gas about 4.5 gallons, I would guess that it's something minor is just a matter of finding the problem
    Jan 2005
    Japan
    Just to make sure that the fuel pump works, test it by adding gas, then test the fuel pump http://www.bimmerboard.com/forums/posts/366521/
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Garage mechanic came by tested fuel pump fuel pump is working
    Jan 2005
    Japan
    Do you or the garage mechanic have a fault code tool like a Peake fault code tester?
    Is the ignition o.k.? Did you check the distributor and rotor? Ignition coil? Crankshaft position sensor?
    Difficult to help over the forum without actual testing results.
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Shogun Could it be the alternator or spark plug related??
    Jan 2005
    Japan
    as mentioned above, ignition = distributor, distributor rotor, ignition coil, spark plugs, crankshaft position sensor.
    Not alternator.
    Question, you mentioned: ...wont start after charge of battery HELP
    Was there a mix up with plus and minus when connecting the battery charger?
    If so, some fuses could have been blown.
    Does the DME relay get power?
    Did you check the fusible links? http://www.bimmerboard.com/forums/posts/377728/
    Jan 2019
    Boston Ma
    1990 BMW 735il
    replace plugs wires rotor and cap about five to six thousand miles ago but mechanic did not gap plugs
    Jan 2005
    Japan
    gapping new plugs is normally not necessary, when you order the correct ones they come ex factory correctly gapped.
    What happened 5000 - 6000 miles ago does not matter, you have to check everything now.
    And please answer the questions above in my post #20.
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Battery terminals and cables was on correctly
    Well look further into ignition and will reply back when further testing is done
    Jan 2019
    Boston Ma
    1990 BMW 735il
    Shogun can you do me favor
    Can I please have your email address for I could send you videos of what the car is doing
    Jan 2005
    Japan
    post the links to the youtube here, the more can see it, the more can post their opinion and can help.
    Try the test forum first how to upload https://www.bimmerforums.com/forum/f...hp?123-Testing
    read these
    525i-no-crank-no-start https://www.bimmerforums.com/forum/s...roblems-solved
    https://www.bimmerforums.com/forum/s...-not-injecting
    https://www.bimmerforums.com/forum/s...t-start-solved
  1. Car wont start after alarm drained battery
    By Bluesman in forum 8 Series (E31)
    Last Post: 12-29-2014, 04:17 PM
  2. 2004 BMW 525i WONT START: Not Starter, Not Battery. HELP!
    By dharman in forum 2004-2010 (E60,E61)
    Last Post: 07-20-2014, 12:36 PM
  3. Car wont start after diconnecting battery
    By Mervon in forum 1996 - 2003 (E39)
    Last Post: 11-02-2013, 07:45 PM
  4. Obd1 m3 wont start after battery jump...no codes, dme?
    By rc000e in forum 1992 - 1999 M3 (E36)
    Last Post: 09-10-2012, 06:32 PM
  5. 1997 M3 wont start after battery disconnect
    By dino0110 in forum 1991 - 1999 (E36)
    Last Post: 06-13-2012, 09:33 PM
