Results 1 to 14 of 14
Thread: Ideas for fixing a key fob / fob holder
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    So let me start by saying I've soldered my fob a half dozen times and it works great.
    But, after 21 years and 235k miles, the plastic where the keychain connects has literally worn through and broken. (See picture below).
    I may just post in the wanted section for a broken fob and replace the shell, but has anyone got any ideas on some kind of way to fix it or otherwise keep the keys attached to the fob?
    Jan 2016
    Ca
    2001 525it
    Plastic epoxy and sanding
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Buy an aftermarket Subaru fob. Or ask Braymond141 if he has any used cases. He reprogram Subaru fobs to work on the E36 — both are alpine fobs but have different programs. I have one of his reprogrammed Subaru fobs.
    Jun 2002
    Crystal Lake, IL
    '10 E90 M3
    You can buy replacement cases for a few bucks on Ebay. Only difference is they have the blue/orange buttons like the Subaru fobs, instead of grey buttons.
    Current Whips: 10 E90 ///M3 - 04 GMC Sierra CCSB - 19 VW Atlas
    Past BMW's:
    85 325 - 87 325is M-Tech 1 - 91 318is S50 swapped - 91 318i 'vert
    97 M3/2 - 98 M3/4/5 (Alpine/Modena) - 98 M3/2 - 98 M3/4 (Dakar)
    06 330xi - 09 335i
    FL
    are slow.
    Braymond141 has them in stock.
    https://www.msportparts.com/collections/electronics
    Well worth just getting one from him than trying to fix it with epoxy. Plus Brett is a cool dude who could use the support
    But if you wan'ted to cheap out, and feel like the buttons do work, and the electronics won't give you an issue, you could always just buy a blank case:
    https://www.ebay.com/itm/2-BUTTON-RE...1/132915487889
    -Dr. Seuss
    Jul 2011
    Austin, TX
    Quote Originally Posted by Hova View Post
    Thanks, I should have searched for Subaru fobs. All of the BMW results were integrated with the key.
    And yeah, as I said all of my stuff works. A new $10 case will more than do the job.
    But I DO need that trunk latch reinforcement he sells.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    I can sell you a new gray button empty shell too. $10
    Jul 2011
    Austin, TX
    Quote Originally Posted by Braymond141 View Post
    Deal! I'll give you a call a little later today and add that to the trunk latch reinforcement plate.
    Thanks!
    Jan 2006
    Oakhurst, CA
    I'll try to have shells on the website today. There's a "hot spot" in them from the injection molding process. Fitment is 10/10, Aesthetics are 9/10 in my opinion. The gray button shells are impossible to find so it's all I could get.
    Jul 2011
    Austin, TX
    I already did it. I just ordered the plate and two Hotwheels, and added a note to the order to replace them with the case. I also sent you an email about it.
    Not worried about the aesthetics - and I'm sure it'll be worn smooth like the old one soon enough anyway...
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by blckstrm View Post
    Got your message and will adjust. Thank you!
    Jul 2011
    Austin, TX
    You really went above and beyond - thank you!
    And this reinforcement plate is great too, but would have fit a lot better if I'd installed it ten years ago!
    Jan 2006
    Oakhurst, CA
    Is your sheet metal that bad?
    Jul 2011
    Austin, TX
    Yeah, sadly.
    It's not terrible - it's installed and closes fine, but it's not completely flush.
    I've been rear-ended twice now (while sitting at a complete stop - not some stupid emergency braking stunt), and have had to punt on fixing the trunk to avoid totaling the car both times. It never made contact with the trunk itself, but the bumper moving under it tweaked the latch and exacerbated the cracks. I'll have to take a picture. One side is sunk and the other is a little high. The plate pulls the sunken side out to where it should be, but the high side doesn't want to move back where it belongs.
    I tried tapping it with my ball peen hammer, but it didn't want to move at all. I didn't want to get too aggressive with it, but maybe I should be a little more aggressive with it and go at it slowly. I thought it would be best to work on it with the latch screws in place, but it may may sense to try it with the screws removed.
  1. Key/ Alarm FOB needed...... WOW on the price
    By FLAJIM in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-11-2013, 05:28 AM
  2. Replies: 12
    Last Post: 10-19-2011, 02:04 AM
  3. WTB: E36 Key Remote Fob
    By vincentjames501 in forum BMW Parts Wanted
    Last Post: 12-06-2009, 05:51 PM
  4. emergency key and fob
    By BMW04 in forum 1995 - 2001 (E38)
    Last Post: 07-27-2007, 08:16 AM
  5. What to do if you lose both keys and FOBs
    By 115sonic in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-28-2007, 07:12 PM
