Results 1 to 7 of 7
Thread: Plastic cooling pipe replacement
    Jan 2019
    Pensacola,FL
    2003 BMW 325i
    Hello all. I am new to BMW, my GF has a 2003 325i with about 161K miles and I am working on fixing several vacuum leaks and have removed the intake manifold. I noticed that BMW uses plastic pipes along the block for cooling. I was planning on doing the normal radiator coolant hoses but when I removed the manifold I noticed the plastic pipes. I am looking for any input on when those should be replaced if at all. I am trying to do as much as I can while the intake is off so I don't have to take it back off in a month or two for something else.
    Thanks,
    Jason
    Jan 2016
    Ca
    2001 525it
    Do the pipes, it was the first thing I did on my car and do the cyclone valves and hoses also
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Jason, go to E46Fanatics and read up there on the procedure used to replace those plastic pipes.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    You have the right idea. Replace it now while the intake manifold is off. It's plastic. It's old. It could cook the engine if it fails and she keeps driving.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jan 2019
    Pensacola,FL
    2003 BMW 325i
    I have the new pipes in hand and even though the part numbers are identical, the new ones have 2 O rings on the end that goes into the block instead of one that the old ones have. Is this a new and improved design that will still work?
    Thanks,
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    The old pipe has two O rings as well. One has broken off and is still in the engine and you'll need to remove it before fitting the new pipe
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jan 2016
    Ca
    2001 525it
    Clean out the holes
  1. Plastic Coolant Pipe Replacement
    By OntarioZed in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 02-19-2018, 04:16 PM
  2. Replacement for plastic cooling system
    By newbiebf in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-22-2011, 10:24 AM
  3. e36 alternator cooling pipe
    By NHbmw325I in forum BMW Parts Wanted
    Last Post: 09-18-2005, 08:33 PM
  4. Cooling system replacement question?
    By NoSoup4U in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-31-2003, 08:39 PM
  5. Plastic Headlight Lens Replacement!!!
    By jblack in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-24-2002, 02:11 AM
