Results 1 to 7 of 7
Thread: pressing in new bushings/ball joints - where to apply pressure
    Jan 2019
    houston
    2017 F150, 97 M3
    So I am redoing my whole rear end currently and just got some parts in. I still need to press out the old bushings. I am doing rtabs, inner and outer bushings/ball joints on upper and lower rear control arms, subframe bushings, and diff bushings. Is there a general rule on where to apply the force from the press or is it different for each piece?
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Press metal not rubber. The outer metal sleeve is good. There are tons of threads with pictures on this.
    FL
    are slow.
    If you have a press it's all pretty simple. Some of the parts might need some persuasion with at torch to get moving, at least the ball joints did for me on my 12-ton harbor freight press.
    Press on the metal if you can. If you can't get the bushings out, use a hacksaw and cut through the rubber into the outer shell, then use a flat head and press in to compress the bushing. It will fall right out.
    -Dr. Seuss
    Jan 2019
    houston
    2017 F150, 97 M3
    I did see the hack saw method to cut through the bushing shell on youtube, great idea. I will be using a 20 ton press.
    Nov 2010
    Whidbey Island, WA
    Quote Originally Posted by DSTX17 View Post
    The press works well on some. Others are easier using a bearing removal/install kit.
    I have a 20 ton press and these:
    https://www.amazon.com/gp/product/B00U3CY8DK/ref=ppx_yo_dt_b_asin_title_o06__o00_s00?ie=UTF8&ps c=1
    https://www.bimmerworld.com/E36-E46-Trailing-Arm-Bushing-Tool.html
    The kit is very useful for things like rear ball joints where their location is difficult to get lined up on a big press.
    The big press was great for rear wheel bearings and front ball joints and the like.
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    For ball joints press on the metal cage the joint sits in. Do not press on the boot or the ball itself. Youll ruin the boot and or ruin the joint itself.
    For bushings press on the metal sleeve the bushing sits in. Some bushings sit recessed inside the metal sleeve and you can use a piece of flat stock across the top to push, just be sure the inner sleeve doesnt protrude past the outer sleeve. But as a general rule, you push on the outer most metal sleeve of a ball joint or bushing.
    Aug 2013
    1999 BMW M3 Coupe
    Yeah, press only on the outer metal sleeve. You want a pipe/socket/adapter which is barely narrower than the outer diameter of the ball joint so it only presses on the outer portion of the metal yet will clear the bore as you press it in.
    The rear end ball joints don't take much force to get in. You can do it fine with a DIY tool from some threaded rod, or even just a mallet once you get them started. The big boys that you need the 20 ton press for are the ball joints in the front control arm. That's not to say you can't use the press if your rear trailing arms are completely off the car. It will press those joints in/out with little effort.
  1. E36 New E36 M3 TMS bushings/ball joints, Powerflex Subframe bushings, AKG reinforcments
    By cbksupreme in forum Suspensions, Springs & Shocks
    Last Post: 09-07-2013, 11:30 AM
  2. SALE New rear ball joints, new thrust arm bushings, iggy switch
    By shanecarmaster1 in forum 1995 - 2001 (E38)
    Last Post: 01-03-2013, 06:44 PM
  3. E36 4 new lemforder ball joints to press into E36 front control arms.
    By PITT M3 RR in forum Suspensions, Springs & Shocks
    Last Post: 11-30-2012, 08:39 PM
  4. New outer ball joints??
    By Shmoe84 in forum 1991 - 1999 (E36)
    Last Post: 09-25-2006, 06:21 AM
  5. Here's the bushing(ball joint) I was talking about.....
    By LY95 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-20-2003, 01:34 AM
