Results 1 to 4 of 4
Thread: Power Steering Fluid Reservoir Leaking?
    Mar 2005
    NH
    E34 540i 6sp 1995-03-28
    Replaced a leaking res today.. hoses looked ok , clamps were good to re-use. filled it and drove... checked it and there some fluid had escaped the lid it seems... thing was as tight as it could get and the thing was only filled to the level indicated on the stick... do these always leak a little?
    NW suburban Chicago
    hiss by my window
    EVERY old BMW I see has a leaking P/S hose at the reservoir. Are you certain it isn't weeping from a hose on the bottom and being blown around?
    Having said that I also see a lot of caked oil and dirt on the caps too. I'm addressing my own currently and will soon know if the stuff up top is really coming from down under.
    That wasn't much help, was it?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    On my E32 the lid has a gasket, but the lid is not sealed completely, there is a small breather hole in the lid, so that cold and warm power steering fluid has space to breath. Maybe you filled too much fluid.
    Mar 2005
    NH
    Quote Originally Posted by shogun View Post
    I'll keep an eye on it. As its a brand new reservoir the O ring is also new .. I never noticed the breather hole before so I'd guess that's where its escaping as it seems to start at the cap and not below..
  1. Relocating power steering fluid reservoir
    By m2pc in forum 1991 - 1999 (E36)
    Last Post: 03-16-2009, 02:52 PM
  2. (E32) what does the ATF power steering fluid reservoir look like
    By garagedoreen in forum 1988 - 1994 (E32)
    Last Post: 04-13-2008, 08:14 PM
  3. power steering fluid (hose) leak, how to flush?
    By zaks z3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-30-2007, 05:27 PM
  4. Power steering fluid reservoir replacement
    By BKarre in forum 1992 - 1999 M3 (E36)
    Last Post: 11-14-2006, 11:38 AM
  5. Replies: 5
    Last Post: 03-13-2002, 01:25 PM
