Results 1 to 3 of 3
Thread: touring rear washer fluid leak
    Aug 2012
    Richmond, VA
    95 525t, 94 525, 87 325
    The rear washer fluid tank has been leaking at the gasket that connects the motor to the tank.
    I've replaced the gasket with the OEM replacement.
    What else should I do?
    CT
    '94 530iT LSx/T56
    Check the pump for any damage, like a crack. If the pump looks good, if it were me, id be using some basic silicone, gasket maker, like Permatex Black, so keep her from leaking.
    -Alex
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Are you sure that's where it continues to leak? If so, check the pump as Henry suggested, and failing that, goop it up with RTV or marine-grade caulk. Also check the tank for cracks. I happen to have one if it needs replacement.
  1. Got a washer fluid leak
    By MJB02SMG in forum 2001 - 2006 M3 (E46)
    Last Post: 02-19-2008, 10:30 AM
  2. Washer Fluid Leaks
    By MLOVE in forum 1992 - 1999 M3 (E36)
    Last Post: 12-05-2006, 06:09 PM
  3. Touring Rear Washer ???
    By IamCatman in forum 1988 - 1996 (E34)
    Last Post: 12-02-2006, 12:58 AM
  4. Windshield washer fluid leak
    By Sa///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-15-2006, 03:18 PM
  5. Windshield washer fluid leaking
    By ///M3N in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-10-2004, 08:40 PM
