Results 1 to 5 of 5
Thread: 2011 335I Charge pipe replacement
    Jan 2019
    Locust, NC.
    2011 335I
    I was traveling and went to pass a car & stepped hard on the gas. As it accelerated, it made a sudden noise & hesitated. I backed off and it seemed to hold speed but I knew something was not right. I pulled over & opened the hood & the charpe pipe connection towards the back was loose. I started back home & the warning lights came on as it started slowing. I looked again & the part of the end was actually gone & there was a large opening.
    I need to replace the charge pipe but should I replace with OEM plastic or after market aluminum?
    I'm not sure what the aluminum pipes cost, but the OEM ones aren't cheap. I would personally like the upgrade, but it may take a few days to get one. Most dealerships probably have the OEM one in stock. Depends on if you have something else to drive or not.
    Jan 2017
    Las Vegas
    Replace the full charge pipe, we offer the VRSF pipe for $149 shipped
    Comes with lifetime warranty
    Product Link
    https://x-ph.com/vrsf-chargepipe-200...n55-e-chassis/
    Can't beat that price! The OEM pipe is way more than that.
    Jan 2017
    Las Vegas
    Quote Originally Posted by White94RX View Post
    Correct and the stock one is plastic which will break again.
    VRSF is aluminum with lifetime warranty
  1. Replacement of Intake Charge Pipe (part# 1371759) covered under CPO warranty?
    By shadowexplorer in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-22-2017, 10:52 PM
  2. Replies: 0
    Last Post: 09-11-2016, 03:59 PM
  3. Need a replacement key with keyless entry-remote access for 2011 335is
    By 3XXM in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-04-2015, 10:23 PM
  4. E9x Charge pipe and Bov for 335i
    By meanstream1 in forum Engines, Performance Parts & Software
    Last Post: 04-30-2014, 12:16 AM
  5. Fitting ZKW with huge AA charge pipe???
    By Scho in forum Forced Induction
    Last Post: 09-18-2004, 02:01 AM
