im having an issue with the fuel pump relay on my 1998 318i. The wire coming from the middle prong connection on the relay has fried itself all the way to the fusable link. ANy suggestions on what to do or where to start? i have a video of the problem here https://www.facebook.com/FilthyyJayy...5364446844795/
Hi,
Do post this in the E46 section or E36 if it's a late build one and ask there. This forum is for car audio.
Cheers, Dennis!
moved to E36 forum
So your going to have to follow the wire on both sides of the relay to find the short. Obviously the relay will also need to be replaced, but not before finding other bad wires. Possibly the pump is at fault.
