Results 1 to 10 of 10
Thread: Xenon lights brightness
    Jan 2017
    USA
    E21, E46
    So I have a question for the forum...
    I have noticed my stock xenon lights are not the brightest. Matter of fact the daytime brights are much brighter, tested by pulling the light lever back...
    How are your xenon lights on your e46? Very bright? As bright as the daytime highs?
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    AL made housings are pretty good, ZKW on the other hand suffer from melting reflector issue which makes HID perform worse than halogen. Your bulbs could be old too, that does make a difference.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    OP, what year is your car?
    Jan 2017
    USA
    E21, E46
    06/2004
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Take a look at the headlight bowls to see if they’ve deteriorated. As noted, ZKW provided some xenon lights to BMW. I think that there was a recall on them. Call the dealer and provide the car’s VIN to see if there’s an active recall on the car.
    Jan 2017
    USA
    E21, E46
    Ok thanks. I know i have checked / asked bmw in regards to recalls and had them resolve all of the issues to date: rear brake light grounds, airbags, 4k dip etc..
    Headlights were not listed in any recalls when i asked however i never specifically asked about headlight or ZKW recalls.
    I will ask them today.
    Peoria, AZ
    ZKW will have a logo on the front, ZKW in a circle.
    Was a 4K dip an official recall? I believe there was a SIB only.
    Jan 2017
    USA
    E21, E46
    Thanks.
    You are correct the 4k dip was an SIB.
    So if the dishes have deteriorated does anyone have an aftermarket fix?
    My guess is they are dull due to limited reflection.
    I will probably take the lights out of the car this weekend to inspect them.
    Jan 2017
    USA
    E21, E46
    Based on the ZKW keyword i found some very insightful threads.
    One of them being
    http://www.zhpmafia.com/forums/archi...hp/t-9810.html
    Thanks for the help on this...
    I now know what to do next..
    Also this link is very informative and probably what my ZHPs issue is
    https://www.bimmerfest.com/forums/sh.../552978?page=4
    And the cheaper fix:
    https://www.theretrofitsource.com/co...kw-repair.html
    Jan 2017
    USA
    E21, E46
    I confirmed today I unfortunately have the ZKWs and the lightbulb bowls are burnt.
    I ordered the 5.0 kit from retrofit source. I will reply back with the results.
  1. Xenon Light Questions (brightness)
    By scrace89 in forum Lighting sponsored by BAVToys
    Last Post: 12-13-2009, 09:22 PM
  2. Replies: 3
    Last Post: 04-05-2002, 04:37 PM
  3. Stock Xenon Light ????
    By JamesB in forum 1996 - 2003 (E39)
    Last Post: 09-03-2001, 02:16 PM
  4. Xenon Lights
    By arrogantBMWdriver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-20-2001, 09:13 AM
  5. For all the JIMMY ("xenon" light boy) lovers (and haters)
    By Seedster in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-01-2001, 12:47 PM
