Results 1 to 7 of 7
Thread: Help with injector coding
    Nov 2017
    Huntington Beach, CA
    2009 BMW 335i
    I have hit a little snag. I am going to replace my injectors this weekend because I have 3 leakers. The new ones are Index 12's.
    The procedure looks pretty straight forward, but I just thought I would look at the coding procedure today as a warm up for this weekend. I have a Schwaben to do the coding. I hooked it up today and drilled down to the screen with the values and instead of just seeing 6 digits to change like all of the videos have shown, under each Cylinder I had 2 matching 22 digit numbers. It looked like this:
    Cylinder 1
    94411625119547117501497
    Each cylinder was like this (different number of course). Has anyone run into this before? I have no idea what values to use now for the new injectors.
    Any help would be appreciated.
    I've never seen that before, but I've never used anything other than OEM software (ISTA), so I don't know what to tell you. I've never heard of Schwaben. You could always write down the injector numbers, and what cylinder it was in. It wouldn't hurt anything to drive it to a local independent shop or dealership and have the numbers coded.
    Nov 2017
    2009 BMW 335i
    Quote Originally Posted by White94RX View Post
    Thanks White94RX. I am running a Dinan Stage 2 tune. Do you know if that would have modified these numbers when it was flashed?
    Nov 2017
    2009 BMW 335i
    Thanks White94RX. I am running a Dinan Stage 2 tune. Do you know if that would have modified these numbers when it was flashed? The tune was there when I bought the car.
    I don't see why it would have changed them.
    Jul 2004
    Houston, TX
    36 Cylinders
    First you would want to confirm if the Schwaben tool even does this process correctly. After all, it's a chinese aftermarket tool that isn't designed to do intense work.
    Original BMW software like INPA or ISTA will do it for sure.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2017
    2009 BMW 335i
    The Schwaben is designed to do this.
    Do I need a dedicated laptop to run INPA/ISTA?
  1. HELP! 97 540i codes for all injectors no start
    By Taseden in forum 1996 - 2003 (E39)
    Last Post: 04-02-2012, 08:21 PM
  2. Need help installing Injectors on 95 M3
    By Bernanke in forum 1992 - 1999 M3 (E36)
    Last Post: 07-16-2002, 09:38 PM
  3. Need help with injector wire for aquamist 2c
    By Stylin in forum Forced Induction
    Last Post: 07-09-2002, 12:29 PM
  4. Help!! Getting OBDII Codes P1188 and P1189
    By bmwguym3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-01-2001, 09:03 AM
  5. Help!!! Replacing Injectors!!!!!
    By SJJ28 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2001, 11:45 PM
