Results 1 to 6 of 6
Thread: reconnection of ebrake cable to parking brake mechanism
    Jan 2019
    houston
    2017 F150, 97 M3
    I am in the middle of removing the rear subframe currently to change out the bushings. I was reading people removed the drive shaft which requires removing the mid pipe because most have the cable get stuck in the trailing arm due to rust. Well I looked at removing the exhaust and those bolts to the header looked like a potentially tough job to break loose. My ebrake cable popped right out of the trailing arm hole using a flat head to pop it backwards towards where the differential sits. Anyway does anyone have pictures of how that pieces that attaches to the ebrake cable on the trailing arm end sits for when I go to reconnect it? I should have taken a before picture.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Quote Originally Posted by DSTX17 View Post
    Here is what the e-brake looks like. The circled area is where the cable attaches. There is a small pin that attaches the cable. I disconnected the cable at the hand brake to get enough play. The cable just snakes through the hole in the trailing arm.
    Jan 2019
    houston
    2017 F150, 97 M3
    thank you this is exactly what I needed!
    FL
    are slow.
    I only get to work on my cars on the weekends between my busy work week. I remember taking my E-brake apart on a Sunday evening, and by the following weekend, I had no clue how to put it back together lol. Fun times. Be patient with it, and test the adjustment before assembling everything back. Usually the E-brake shoes will last a very very long time, I haven't ever changed them, and they still have no problem locking up the rear tires when adjusted correctly. Good luck.
    -Dr. Seuss
    Aug 2013
    1999 BMW M3 Coupe
    Yeah same for me. Once I was able to took at some pictures online and then sort of piece it together and figure out how the mechanism worked it made a lot more sense. When the cable is pulled the fitting the the end of the cable sits in is pulled inboard which expands the little hinged lever mechanism and pushes the two brake shoes apart. The other deal at the bottom is just an adjuster used to get the shoes in the right ballpark so they aren't dragging but they also don't need to be pressed much to make contact. The PITA part is getting the stupid springs back on, specifically the last spring. Have fun with that. It involved a pair of needlenose pliers and a lot of swearing.
    NY
    skateboard
    Just what I was looking for. The OP of my car removed the ebrake cables entirely (smart move right).
    ― George Orwell
  1. ebrake cable disconnect at brake pads
    By jpilk99 in forum 1991 - 1999 (E36)
    Last Post: 04-10-2013, 10:37 AM
  2. Snapped threaded end of cable off parking brake
    By randomy in forum 1991 - 1999 (E36)
    Last Post: 08-22-2009, 01:11 PM
  3. can't get parking brake cable out of rear trailing arm
    By dshilkit in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-29-2004, 11:20 PM
  4. Who sells parking brake cables?
    By nat325i in forum 1991 - 1999 (E36)
    Last Post: 01-09-2003, 03:13 AM
  5. Is there a way to tighten the parking brake cable?
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 08-15-2001, 01:13 AM
