Results 1 to 6 of 6
Thread: Power windows
    Mar 2018
    Asia
    1992 E32 M60 V8 RHD
    Power windows
    Hi all,
    i've tried to search throughout the forum, but no avail/close answers
    since my e32 is RHD, driver side is on the right, left is passenger, so...i remember i have all the windows working, but now the passenger front (Front left) is not working, rear right is intermittent [70% of the time works]. driver side is also intermittent[ 90% of the time works] only once in a while it will not respond to the switch, all auto up and down is working on those with "known working" windows. i need a guide on where to start with this one..if it works, it sounds like the window is going up and down smooth no hesitation or motor forcing going up and down..
    1990 730i M30B30 RHD - Sold
    1993 730i M60B30 RHD
    Others:-
    2012 Toyota Fortuner 4WD 3.0
    2012 Kia Optima 2.4L
    1990 Suzuki cavalcade (motorbike for hobby)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Did you already check the wire looms from A-pillar to doors? Often the wires break there, especially on the door which is mostly used = driver door.
    Mar 2018
    Asia
    1992 E32 M60 V8 RHD
    shogun,
    i tried, but the rubber sleeve seems to be not moving when i pulled it, any specific way to move the rubber sleeve to access the wire looms? should it be pulled away from the door towards A-pillar or from the A-pillar towards the door?
    Others:-
    Jan 2005
    Japan
    there are some instructions on the shop manual, 41-51/2 41 51 080 https://www.bmwtechinfo.com/repair/main/Index_cd3.htm
    under removing and installing left or right front door.
    There you can see how to pull the plug connector out of A-pillar and unlock the connector. I also had removed the door cards, as I wanted to check the entire wire loom.
    see also here: Kabelbruch Tuer links hinten http://bmwe32.pagaduan.org/ click that on the left and a new side will open with pics, there you can see that the broken wire loom in that case was inside the door
    Mar 2018
    Asia
    1992 E32 M60 V8 RHD
    Alright shogun, thanks for the heads up and details. i will tackle this as soon i get free time after work
    Others:-
    Mar 2018
    Asia
    1992 E32 M60 V8 RHD
    so after a while, i manage to get into wire loom, inspected every wires, nothing broken, i guess i need to find out if theres power supply going to the motor or not..could be switch, could be bad window motor
    Others:-
  1. Power window problem on 325is..
    By JBoz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-21-2005, 04:50 PM
  2. Power windows
    By ryanbmwm3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-28-2001, 04:06 AM
  3. Driver's power window won't gap.
    By Bobby Walker in forum 1991 - 1999 (E36)
    Last Post: 08-12-2001, 11:18 AM
  4. Power Window Vents for Coupe
    By jmciver in forum 1991 - 1999 (E36)
    Last Post: 07-09-2001, 02:27 PM
  5. Driver's side power window
    By bungy42 in forum 1991 - 1999 (E36)
    Last Post: 06-28-2001, 04:58 PM
