RM European Auto Parts
Results 1 to 3 of 3
Thread: Suggestions for little tweaks
    Jan 2019
    Pittsburgh
    1987 e325i sedan
    So I recently picked up a pre change 87 325i. It came with ie headers, 2.5 exhaust, and needing a top end rebuild. Since I have it apart I thought I would throw some money at it. Besides 4hole injectors is there any other mechanical upgrades I should invest in?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I have never heard of "4-hole injectors" being an upgrade for the M20 engine. Stock BMW injectors can handle an additional 20-25% power upgrade, and personally, I'd recommend sending your stock set off to RC Injection in California, for complete testing, ultrasonic cleaning, refurbishing, and re-testing. with precise printed results of before and after. Cost: $25 per injector - the best bargain in the automotive world.
    Tweaks? Best one will be a good Schrick camshaft. Depending on mileage, a bottom-end refurbish might be in order. If you can't see good crosshatching, or it's gone on one side of the bores, maybe pistons and rings and overbore; otherwise, maybe just a quick hone and a new set of rings.
    You can, of course, do a full on stroker, up to 3.2 liters, if you want serious power increases. See Ireland Engineering for these kits.
    Whatever else you do, or don't do, make sure to replace the complete timing belt kit (with Continental!), and the water pump, thermostat, hoses, expansion tank and radiator.
    Nice car - Best of Luck!
    Chris Powell
    BMWCCA 274412
    Jan 2019
    Pittsburgh
    1987 e325i sedan
    hey, thanks for responding again. you seem to know your motors. from what i have seen so far it seems like this car really has less than 40k on it. no wear and lots of neglect, so the bottom is almost new.
    i am not into serious power. i have an full 2jz gte in storage, if i want power i can just swap it. i bought a 325i because it is a great "package" car. Good motor and handling and just fun. cams might be good. i will do some reading.
    the "4 hole injectors" refers to bosh gen 3 injectors, like from a ford. matched sets go for about $45. not sure if it will boost power, but should make it run smother and give a slight boost to mpg without a major remap. check out the vid, it makes the difference obvious. Thanks for the suggestion for a cleaner though.
    https://youtu.be/VfynoxL2RZI
    i am still working on the top end. parts problems. tried a few different suppliers, i am on pelican parts now. they at least shipped on time and knew that i needed a 2 port water pump without me telling them.
  1. Dear Little Bunny Foo Foo (WTB E36 M3 lip/taking suggestions)
    By SixSquared in forum Georgia sponsored by Harrison Motorsports
    Last Post: 03-09-2011, 06:39 PM
  2. new sig thanks to TopEndRacing and a little tweaking by muah
    By surfnskate in forum BMW Rides & Events
    Last Post: 01-22-2008, 10:35 PM
  3. Need a little help/suggestions
    By tparrish711 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-17-2007, 02:31 AM
  4. Just picked up this little e30, any suggestions?
    By Snarcher! in forum BMW Rides & Events
    Last Post: 07-30-2006, 02:01 PM
  5. little more info/suggestions to help me choose suspension
    By audiodemon in forum 1991 - 1999 (E36)
    Last Post: 01-26-2005, 12:02 AM
