Results 1 to 9 of 9
Thread: 750il gas leak under hood
    Jul 2017
    dalton, pa
    1997 740il
    Is there a common leak on 1999 v12 front passenger side of engine? Its so cold out to start taking parts off randomly to see whats leaking. If I had an idea of where to start it would be great.
    Thank in advance, Jake
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E38 forum
    May 2009
    Lithuania
    E38 750i FL & E36 M3 4DR
    You need to replace fuel lines. Get new ones or re-do end clamps.
    http://bmwfans.info/parts-catalog/E3...ection_system/
    Part # 12 and 13
    May 2013
    Rochester, NY
    2001 740i Sport
    Assuming the V12s have it like the V8s do, also check the short piece of rubber fuel line that connects the 2 sections of hard line right by the passenger side shock tower (next to the engine).
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    Well the fuel filter sits under the right front seat plus IIRC a few other fuel connections
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Yep, there's a line that makes a sharp turn up front, left side facing the car. When cold it leaks, then expands with engine heat in most cases and stops. I've seen this a lot. Follow the fuel lines up the passenger side and you'll see it. It's a molded line, so youll want to order it from BMW.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    May 2013
    Rochester, NY
    2001 740i Sport
    It is molded, but I was able to make a suitable replacement out of regular fuel injection hose. The bend is a little on the tight side for it, but once the car was run and got up to temperature with pressure in the line, it formed to the bend just fine and wasn't squished at all.
    Jul 2017
    dalton, pa
    1997 740il
    Thank you all for the info. This is a great site. Jake
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by rslifkin View Post
    Wonder if that's what's causing my gas smell. I haven't found an egregious leak, but definitely smell gas in the mornings when the car is cold.
    Another thing to put on the list. Might have my shop tackle this next time I'm in.
  1. Oil Leak Under Hood
    By rollingdirty1 in forum 1999 - 2006 (E46)
    Last Post: 01-09-2013, 03:12 PM
  2. fuel smell or leak under hood / drivers wheel
    By SHOracer in forum 1991 - 1999 (E36)
    Last Post: 08-01-2012, 09:25 PM
  3. Gas leak under the engine
    By stas2007 in forum 1995 - 2001 (E38)
    Last Post: 01-03-2011, 08:59 AM
  4. Help. EVAP large leak and STRONG Gas Smell Under Hood
    By rguil15 in forum 1991 - 1999 (E36)
    Last Post: 06-07-2010, 08:05 PM
  5. Steam from under hood, but no leak?!?
    By jfischetti in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-05-2003, 09:14 AM
