Results 1 to 4 of 4
Thread: 2005 BMW E46 330Ci Door Glass
    Aug 2011
    Sarnia ON Canada
    2005 330Ci
    When the doors are closed the glass after 5 seconds lifts up the last few millimeters to complete the seal on the rubber and gives out a small bumping noise. The passenger side has stopped doing this, and occasionally the dash shows the door is open when its clearly closed. Does this mean that the door latch mechanism is faulty ? All very strange!
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Yes, one of the internal microswitches in the latch mechanism is going bad.
    Aug 2011
    Sarnia ON Canada
    2005 330Ci
    Quote Originally Posted by dhurley34 View Post
    Thanks for yr input. Do know if the whole of the latch assembly must be replaced, or is it possible to replace the micro switch.In any case I assume thatthe latch mechanism must be removed from the car door...what fun..a big job I suspect.
    Aug 2014
    Lawrence Kansas
    The whole latch assembly must be replaced. Been there done that.
  1. Replies: 3
    Last Post: 10-07-2016, 02:19 PM
  2. E46 Bmw e46 330ci 325ci coupe convertible side view mirror
    By fmzip in forum Exterior Lighting & Body Parts
    Last Post: 02-27-2012, 10:35 PM
  3. E46 2001 BMW e46 330ci engine
    By 2005bmw330ci in forum Drivetrain & Transmission Parts
    Last Post: 12-27-2011, 06:14 AM
  4. E46 Used BMW E46 4-Door Sedan Clear Corner Lights
    By 1998 in forum Exterior Lighting & Body Parts
    Last Post: 08-01-2011, 01:27 PM
  5. E46 FS: 2003 BMW E46 330ci
    By IanK in forum 3 series & Z Series
    Last Post: 05-16-2011, 11:00 AM
