Results 1 to 12 of 12
Thread: Here is a weird one I don't know how to title
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    2003 330i zhp, 6 speed, ~185K miles, pretty healthy car overall, no lights on the dashboard.
    I went to pass somebody on the highway yesterday and put the pedal to the metal flat in 6th gear. Car started to accelerate as expected from 2.5k RPM. At 3K RPM, tach needle went to 4K faster and came back to 3K on its own. Mind you, at that time the car kept accelerating at a normal rate, but I could tell that it wasn't just a weird act on behalf of tach needle - the sound of the engine also indicated that it revved up to 4K and came back down. Most importantly, car kept accelerating normally through this weird behavior. The car acts the same way in 5th, 4th and 3rd gears as far as I can tell and it seems to fall under 3-4K RPM in any gear. This really got me stumped. I really have no idea where to begin troubleshooting.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Clutch?
    Peoria, AZ
    Was my initial thought, but clutch is disengaged throughout this "ordeal", no?
    Jan 2016
    Ca
    2001 525it
    How old is the clutch, typically if you are cruising a city street type speeds in high gear accelerate quickly the rpm's go up but the car really does not. If you back out of the throttle, then it feels normal, for awhile.
    Aug 2014
    Lawrence Kansas
    Quote Originally Posted by Mless5 View Post
    Not if its slipping while at maximum torque load (higher gears/less mechanical advantage).
    Peoria, AZ
    Quote Originally Posted by jclausen View Post
    I wish there was some way to tell, I haven't replaced it in my 25K miles of ownership.
    Quote Originally Posted by dhurley34 View Post
    Sounds like it may be it...
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Clutch is likely going bad.
    Jan 2016
    Ca
    2001 525it
    Take to a BMW shop and have them drive the car, if it's slipping techs know how to induce it
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Clutch
    Classic test is to get into 3rd gear, run up to say 3000 rpm and hold the car back with the brakes while you keep the pedal floored. If the engine rpm 'flares' then you have a slipping clutch.
    The clutch can be inspected visually from below I think there's a plate or viewport or perhaps a cable/viewer can see the clutch thickness.
    Besides, at 185K (and it's not an M either...they tend to last longest if you don't abuse them) it's not unlikely you need a new clutch and pressure plate and throwout bearing.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    You could also have a leaking rear main seal...
    It would cause slippage until/unless the oil is burned off the clutch plate/facing.
    Peoria, AZ
    Turned out to be worn clutch along with flywheel that has excessive wobble to it and disintegrated fork pivot. Clutch disc had uneven wear due to excessive play in flywheel, but was not at critical stage yet - I am glad I caught this before it completed chewed itself up! Thanks for help!
    Aug 2014
    Lawrence Kansas
    Good catch. Glad you got it sorted.
  1. Weird issues - see if you know what it is
    By Bmwkid3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-21-2007, 02:20 PM
  2. Clutch stop problem...weird!
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 04-20-2001, 09:55 AM
  3. weird chirping sound
    By FLiPModE in forum 1991 - 1999 (E36)
    Last Post: 04-15-2001, 01:20 AM
  4. Weird headlight problem
    By Zippy M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-26-2001, 03:28 PM
  5. Weird "Auto Locking"
    By Rene_328ic in forum 1991 - 1999 (E36)
    Last Post: 03-11-2001, 06:36 AM
