Results 1 to 6 of 6
Thread: unable to connect my iPhone to E93 Bluetooth
    Jan 2019
    UAE
    2008 BMW E93 330i
    Hi folks,
    Although that Bluetooth setting in my car is set to "Active", and I also tried to disable and enable it again, and clicked "Pair New iPhone" where a message came indicated the car's Bluetooth name; my iPhone and other even HTC weren't able to discover car Bluetooth system. Any idea?
    One more question, what is the best diagnostic software and adapter for BMW (i.e: Audi has VAGCOM VCDS)
    Thanks,
    Oct 2012
    washington, dc
    96 E36 Vert 03 E39 M5
    Is your Bluetooth working ?
    On my e90 sedan the Bluetooth device is in the knee/kick panel on the drivers left . If someone removed the lower cover they may have disconnected the receiver .
    Softwarewise I’ve been using Carly for years .
    Otherwise I’d recommend the BMW software. I have a virtualBox OVA somewhere with all the stuff. Just need a laptop with the virtualBox
    http://www.bmwmregistry.com/detail.php?id=13792
    * E39 M5 SterlingGray -RIP 11/2018
    * E36 328 vert Schwarz - ~TurboProject underway
    * E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
    Jan 2016
    Ca
    2001 525it
    So when you pair, get the car in get the pairing mode, search devices in the phone, finds car, a number that comes up on the phone, Like bmw12354, I believe you then tap the number and the screen on the phone displays a key pad you would say. You enter the security code say 1234, then at the top of the phone it would say pair, tap that. The car info comes up with 0-9 listing you enter the 1234 and press ok then it's paired
    Jan 2019
    UAE
    2008 BMW E93 330i
    What is the adapter I need? I don't think that VAGCOM VCDS for VW group OBDII adapter will work. In addition, I previously purchased $15 OBDII adapter but it doesn't seem to work properly on iOs Carly app (it keeps shwoing high and duplicates number of faults)
    P.s: can you share with me the stuff you have and what adapter are you using?
    Jan 2019
    UAE
    2008 BMW E93 330i
    the problem was that my iPhone is not discovering BMW Bluetooth (although it is enabled). Suddenly it is now discoverable. I had just to keep trying the search
    Oct 2012
    washington, dc
    Quote Originally Posted by waelaburezeq View Post
    If the key is on it should be active [dash lights on etc].
    The antenna on my sedan is under the knee panel near the bonnet release . [black module].
  1. Connecting sound to 54 pin (bluetooth install)
    By fmorelli in forum 1996 - 2003 (E39)
    Last Post: 12-16-2008, 04:04 PM
  2. a setup that works for iphone 3G and bluetooth?
    By geordiepaul101 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-12-2008, 05:54 AM
  3. IPHONE 2.0 - Bluetooth ULF RESULTS!
    By sondiego in forum 1999 - 2006 (E46)
    Last Post: 07-10-2008, 08:30 PM
  4. OPPS/DK head unable to connect to GT1
    By M808 in forum Diagnostic Software
    Last Post: 08-31-2007, 11:50 PM
  5. obd 2 unable to connection
    By wysockib in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-10-2005, 11:40 PM
