Jehnert BMW 5 Series E39 Door boards with 3-way sound system.
Fits BMW E39 M5 Doors. This system sounds f*ing amazing! It’s made by Jehnert and includes four 6” mid-bass woffers, 4” midrange, and 1” tweeter. Can sell with or without the full door panels.
Please see full specs here:
https://www.ebay.com/itm/20256551346...84.m1555.l2649
Jehnert Description
Quadruple bass system 4x 160 mm (6″) JEHNERT »POWER WOOFER« per side
Beautifully adapted to the line design • optional with or without cutout for the seat memory switch in the driver side panel – see order information
car-specific sound system
Midrange speaker above the bass line in the panel • high quality Neodymium softdome tweeter in standard cutout next to the gill bars of the vehicle door • clearly structured sound • pleasantly spatially • extremely powerful low bass range • high level stability
sound characteristics
enormously level stability, pleasantly spatially, powerful low bass
Additional information
CAR BMW 5er E39 Limousine / Touring / M5 MATERIAL Glasfibre Reinforced Plastics COVERING Kunstleder COVERING STANDARD COLOUR black STANDARD BASKET 165MM MADE TO FIT Anpassung an Paneel notwendig CUT-OUT DIAMETER 144 mm OUTER DIAMETER 165 mm MAX. INSTALLATION DEPTH 65 mm TWEETER 1x 26 mm Neodym-Softdome-Hochtöner MIDRANGE DRIVERS 1x 100 mm High-End Mitteltöner WOOFER 4x 160 mm JEHNERT »POWER WOOFER« CROSSOVER CIRCUIT JEHNERT fahrzeugspezifisch, akustisch eingemessen POWER HANDLING NOMINAL/PEAK 2 x 300 / 500 Watt FREQUENCY RESPONSE 49-22.000 Hz RECOMMENDED AMPLIFIER POWER ab 2x 200 – 300 Watt / 4 Ohm PRODUCT DETAILS auf Wunsch mit Ausschnitt für Sitzmemory- und Alarm-Schalter Paneel mit Öffnung für Sitz-Memory-Schalter CAR DETAILS 4-türig auch für Fahrzeuge mit Tür-Airbag elektrische Fensterheber ORDER INFORMATION 76148 mit – 75148 ohne Öffnung für Sitz-Memory-Schalter im Paneel
Contact:
Did I just buy these from you on eBay? If so, super excited!
