Results 1 to 9 of 9
Thread: '96 Z-3 seat belt light stays on
    Dec 2018
    Senegal
    '98 Z3
    Howdy! I know the Car Talk guys would recommend just putting a piece of black tape over the offending light, but I'm wondering if anyone knows how to fix this thing? Is it something I can do?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Have you tried buckling the passenger seat seatbelt? The passenger seat occupancy sensor could be bad. Also, check both seatbelts’ “receiver” (the part into which the seatbelt “tongue” goes) for debris. There’s a switch in each receiver. It senses when the seatbelt tongue is properly in the receiver.
    Are you experiencing any other electrical or electronic issues?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to Z3 forum
    Dec 2018
    Senegal
    '98 Z3
    Marco, no. No other electrical problems. I'll check the passenger side and debris probs as you suggested. Thank you.
    Shogun, I'm not sure what the 7 series has to do with the Z-3. Suggestions?
    May 2015
    Maryland
    1998 M Roadster
    Try spraying some contact cleaner into the receiving latch. I have had good results with Deoxit D5 which is safe for plastics. It is a bit pricey but it works and some cleaners are hard on plastics. It normally take time and several latch cycles and applications to clean up the contacts so be patient. Also good for stuck window switches, door light switch, etc.
    https://www.ebay.com/p/CAIG-DeoxIT-D...1785144&chn=ps
    Feb 2009
    Charlotte, NC/Denmark
    2K Z3 2.8
    During taking my drivers side seat apart I found the wire to the seat belt receptacle to be crushed and compromised. Perhaps worth a check?
    Zed's dead baby. Zed's dead.
    Jul 2004
    Houston, TX
    36 Cylinders
    Is your airbag light on too?
    First step here should be to read the codes.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2018
    Senegal
    '98 Z3
    Quote Originally Posted by CoconutPete View Post
    I will do that. Thanks. I'm waiting for a warm day!
    No. Only the seatbelt light. I will check at an autoparts store to see if they have a code-reader I can use. Good idea. Thanks!
    Aug 2017
    Auto parts store code reader won't read SRS & airbag codes.
  1. air bag and seat belt light stays on
    By wxwdatdudewxw in forum 1996 - 2003 (E39)
    Last Post: 06-19-2012, 12:53 PM
  2. Seat Belt Light Stays On
    By Krewzer in forum 1999 - 2006 (E46)
    Last Post: 02-24-2008, 02:42 PM
  3. seat belt light not working?
    By ChosenGSR in forum 1992 - 1999 M3 (E36)
    Last Post: 08-26-2006, 04:43 PM
  4. How do you turn off the seat belt light?
    By sl0moti0n in forum 1988 - 1996 (E34)
    Last Post: 01-28-2004, 10:34 PM
  5. Fasten Seat belt light
    By BMW11 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2003, 11:51 AM
