Results 1 to 3 of 3
Thread: '96 Z-3 seat belt light stays on
    Dec 2018
    Senegal
    '98 Z3
    Howdy! I know the Car Talk guys would recommend just putting a piece of black tape over the offending light, but I'm wondering if anyone knows how to fix this thing? Is it something I can do?
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    There's a switch in the buckle catch. Check the wiring to the catch. You may have to remove the seat to do that so treat all wiring under the seat with care.
    Don't go poking around with an ohm meter in any yellow connections as they are to do with the airbag system and you might discharge the belt tensioner or airbags.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    OKC
    99MC, 06MR, 85M6, 97M3
    As noted this is likely the seat belt switch in the buckle. I'd start with spraying some compressed air in there as well as some electrical contact cleaner. Then lubricate with a spray lube and work the buckle a few times. (lay some towels around the interior before you spray the cleaner and lube).
    99 M Coupe
    06 Z4M Roadster (1 of 1)
    85 M635CSi (Euro)
    97 M3 Coupe (Track)
    95 M3 Coupe
    91 850i 6MT
    11 E93 M3
    16 X5 35x
    16 Chevy Tahoe 4WD
  1. air bag and seat belt light stays on
    By wxwdatdudewxw in forum 1996 - 2003 (E39)
    Last Post: 06-19-2012, 12:53 PM
  2. Seat Belt Light Stays On
    By Krewzer in forum 1999 - 2006 (E46)
    Last Post: 02-24-2008, 02:42 PM
  3. seat belt light not working?
    By ChosenGSR in forum 1992 - 1999 M3 (E36)
    Last Post: 08-26-2006, 04:43 PM
  4. How do you turn off the seat belt light?
    By sl0moti0n in forum 1988 - 1996 (E34)
    Last Post: 01-28-2004, 10:34 PM
  5. Fasten Seat belt light
    By BMW11 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2003, 11:51 AM
