Results 1 to 16 of 16
Thread: Bell-housing bolts and where to get them
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    Question Bell-housing bolts and where to get them
    So in the midst of a clutch job I was removing my trans and realized I had.... 9 bolts instead of 10 between the bell-housing and engine block.
    Instinct told me to just search for the bolt and get it ordered but all I can find is e12/90mm etc. Is this because these bolts are big enough to replace my missing e14?
    Anyway I included a picture to maybe help locate the bolt I need. Cheers!
    *Edit
    Figured it all out and will save you the time of going through the thread. Buy all brand new bolts, its $30 USD... worth the money IMHO.
    These are the correct bolts and the amount you need for this specific application.
    BKLYN, NY
    98 M3/4/6, 16 M3/6
    You can get them at the dealer or online. Looks like the missing bolt is M12X90 Part# 23001222894
    http://www.realoem.com/bmw/enUS/show...diagId=23_1265
    FL
    are slow.
    Conside changing one of those bolts that are in the light gray. It looks like the head is deformed. If you plan on keeping the car for a long time, or changing the clutch again down the road, you might have a hard time getting it off.
    -Dr. Seuss
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    Okay thank you!
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    Quote Originally Posted by hc1001 View Post
    I just want to be 100% sure before paying $10 shipping on a $2 bolt... The top bitch bolts that are e14 are IN FACT m12x90??
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Sometimes people mess up the heads using an impact with the wrong size torx socket. You should be able to match up the bolt you need on real oem. Torx M14 x 90mm are the fattest and longest of the bell housing bolts as I recall. You might add some items to the order and get free shipping if there are other parts you need. Oil filters, etc.
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    I've always considered it good practice to renew all of those bolts. They're not expensive.
    Neil
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Quote Originally Posted by NeilM View Post
    Neil
    +1
    Dublin, OH
    '95 M3, '17 Civic Si
    Quote Originally Posted by JitteryJoe View Post
    +1
    +1
    -Rich-
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    I mean theyre all in good condition but from past experiences Ill just have to take you up on that deal.
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    Just being sure, this is my cart on Pelican. Do these all look correct? They do to me.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by probioticx View Post
    You need 2 of the first on (starter bolts) and 3 of the last one (bellhousing to oil pan bolts)
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    Quote Originally Posted by ScotcH View Post
    Good catch, thank you.
    Sep 2017
    Reno, Nevada
    1994 325is M3 Clone
    One last question.. I see washers on some peoples builds. Why would you use a washer on this bell housing?
    Jun 2005
    New England
    These bolts have good sized round flanges that are like a washer. I see no need for a washer. The factory does not use washers. If I was missing a bolt or damaged one and had to swap in a regular hex head or an Allen head bolt, I would use a washer.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    There are no washers used on those bolts. I don't know what builds you are looking at, but look at better builds.
    There's really no need to replace these bolts unless there is head damage to the etorx. The ZNS3 coating is good to renew if failed, but they are a standard bolt more than capable of repeat use. That's coming from someone who often purchases OEM hardware.
  1. help i mixed up my bell housing bolts
    By rbhanks in forum 1988 - 1996 (E34)
    Last Post: 01-19-2010, 10:57 AM
  2. Bell Housing Bolts??
    By SHARKBITEATTACK in forum 1991 - 1999 (E36)
    Last Post: 03-18-2009, 04:13 PM
  3. cant get the last bell housing bolts out
    By 97Calypso328I in forum 1983 - 1991 (E30)
    Last Post: 02-05-2006, 09:03 PM
  4. bell houseing bolts???
    By 93bmw325is in forum 1991 - 1999 (E36)
    Last Post: 03-18-2005, 06:39 PM
  5. bell housing bolts
    By nick325i in forum 1991 - 1999 (E36)
    Last Post: 09-15-2003, 11:39 AM
