Results 1 to 2 of 2
Thread: 2001 325xi No crank No start, Power to starter
    Jan 2019
    Concord, NC
    2001 BMW 325xi
    I have ran into a no crank no start issue with lights on the dash coming on but the abs light will sometimes stay on after i turn the ignition off. I had bmw diagnose thinking it had something to do with the EWS. They said it was my starter so i replaced it. Still no crank no start. Battery tested good with voltage and cranking amps. I bench tested the old starter and it works. I was able to bump start it. So the problem lies between ignition and starter that makes me think something is inhibiting the starter from cranking. While my starter is getting power from the red wire as well as the black wire as i have tested with a circuit light. I noticed the black and yellow wire that leads to the starter also lights up when i turn the ignition on and the light will stay lit up for a second or two once i turn the ignition off. Any info would be greatly appreciated!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What is the voltage at the main power connection on the starter when the ignition is in the start position? I ask because the power cable that originates at the battery is mechanically joined to the starter’s main power cable at the underhood jumper post under the red plastic cover. There have been reports of that connection corroding. That corrosion prevents the proper amperage from getting to the starter.
  1. 97 528i No Crank, No Start, Not the Starter!
    By SCoRPioN777 in forum 1996 - 2003 (E39)
    Last Post: 12-05-2019, 11:40 PM
  2. 2001 740il no crank no start. Purchased at auction this way.
    By ctiedje03 in forum 1995 - 2001 (E38)
    Last Post: 08-17-2018, 05:10 PM
  3. 2003 BMW 325xi Long cranking then start
    By CynthiaK in forum 1999 - 2006 (E46)
    Last Post: 03-12-2017, 05:34 PM
  4. 325xi Wagon won't Start? Battery or Starter?
    By witness in forum 1999 - 2006 (E46)
    Last Post: 05-27-2013, 11:19 AM
  5. 2001 745il no cranking/no start
    By mahiluck in forum 1995 - 2001 (E38)
    Last Post: 06-18-2011, 02:26 AM
